NOS parts for sale
  • C7OZ-13A805-E 2 Deluxe steering wheel horn ring, both have C5 $150.00 each
    C8ZZ-16A550-A 1 Pair of accessory mud flaps $250.00 /pr.
    C5ZZ-13734-A 3 Console lens $25.00 each
    C7OZ-16098-A 4 GTA fender emblems $100.00 /pr.
    D1AZ-3B584-A 1 P/S pump seal and gasket kit $45.00
    C3OZ-16228-B 4 289 fender emblems $50.00 each
    C5ZZ-15510-A 1 Box of 5 parking or backup lens gaskets $20.00 for box
    C5ZZ-7A624-B 1 Clutch pedal pad, with indent $75.00
    C5ZZ-2457-G 1 Brake pedal pad for manual trans, with indent $50.00
    C5ZZ-5C299-A 2 GT exhaust trumpet bezels $100.00 /pr.
    C5OZ-6243505-B 2 Trunk lock kit $75.00 each
    C6ZZ-8221-A 1 Grill molding center cover $50.00
    C7ZZ-6522811-C 1 LH lower door hinge, '68 style $100.00
    C5ZZ-6522800-B 1 RH upper door hinge $50.00
    C7AZ-16606-A 1 F hood letter $30.00
    C7AZ-16606-B 1 O hood letter $30.00
    C7AZ-16606-C 1 R hood letter $30.00
    C7AZ-16606-D 1 D hood letter $30.00
    D1ZZ-6540282-A-G 1 Set of MUSTANG stick on letters $100.00 for set
    C4DZ-6222404-A 1 65-66 and 69-70 Door handle, FoMoCo box $150.00
    C4DZ-6222405-A 1 65-66 and 69-70 Door handle $150.00
    *SOLD* C4DZ-6222454-A 2 65-66 and 69-70 Door handle push button kit, FoMoCo boxes $75.00 each
    C5OZ-13341-B 1 Turn signal switch $150.00
    C5ZZ-6524100-AFE 6 65-66 Std. interior door arm rests, white $40.00 each
    C4AF-11450-A 2 Starter solenoid, FoMoCo and REPCO on top, no boxes $200.00 each
    C5ZZ-2A635-E 2 Rear parking brake cables, '65 only $125.00 each
    C5ZZ-7652806-B 2 Convertible top tension cable, 65-68 $50.00 each
    C5ZZ-13434-B 1 Tail light housing $150.00
    C5ZZ-3590-A 2 V8 pitman arm $75.00 each
    C3DZ-3047-A 3 Upper control arm shaft kits, with grease fittings $75.00 each
    C5ZZ-2A602-A 1 65 parking brake equalizer bracket $50.00
    C3DZ-3020-A 2 Front coil spring cover rubber bumpers 65-68 $50.00 /pr.
    C4DZ-16707-A 1 Hood latch support, '8 1' date, FoMoCo label $50.00
    COMB-6443720-C 1 Trunk gasket, coupe/convertible only, original style material $250.00
    C5AZ-13480-B1 1 Brake light switch, FoMoCo with C5GB-13480-B stamping $50.00
    C3AZ-14413-B 1 NOS glovebox light assy. 65-68, small push pin, green wire $75.00
    6TPZ 1 NOS FoMoCo AM radio, Philco, starts with '5' $550.00
    C4DZ-18578-A1 1 Early style heater fan switch with off in middle position $50.00
    C3SZ-10316-B 1 Voltage regulator, D2TF motorcraft cover, can be swapped for a different cover, has correct base for 65 and up $200.00
    C4ZA-18808-A 1 NOS dash speaker for 65-66, Bendix, FoMoCo ink stamp $150.00
    1 Used 9" ring and pinion, 3.25 ratio, OEM Ford, very nice $100.00
    1 Pr. of 65-66 hi-po exhaust manifolds, original with '65 dates $500.00
    1 Black NOS '65 dash pad $350.00
    Edited once, last by caspian65 (June 7, 2010 at 6:46 AM).
