Hipo Clutch disc & p. plate info??
  • I've got what seems to be an original 8 spring disc from a Hipo application, and also a coresponding pressure plate.
    Can anyone tell me where to look (I have looked) for a part number on these so I can tell for sure what I have? Thanks
    Edited once, last by 6hypo5conv_old (June 27, 2011 at 7:28 AM).
  • In looking at Tony's Hipo book there are part numbers listed for each piece, but I sure can't find any on these.
    I feel that I have found an original Hipo setup espessely the 8 spring disc....
    Edited once, last by 6hypo5conv_old (June 27, 2011 at 7:31 AM).
  • You will not find Ford part numbers stamped on the disc and pressure plate. The most number that may find would be ink stamped onto the friction material and that would only survive if it was not used as the first time you engage the clutch it would wear off.
  • I just sent you a PM on this.
