wanted 289 hipo engine 7E casting date
Are you looking for a complete hipo engine or a block to rebuild. I just passed on a standard bore,I believe 7C date 289 block.
would like block /heads /crank /caps and any thing else thats special to hipo block i have a 66 hipo engine want to replace it with one closer to build date so really need a 7E WOULD TAKE A LOOK AT 7C
what are you going to do with your 66 hi po block? If you are willing to part with it, what is the date code? Thanks
Quote from wm65
Can you let be know if this is still available? I'm in NorCal...where RU and where is the 7C block?
well sell the engine but need the 7E engine first
