WTB HiPo flywheel
  • The flywheel I have came off of a HiPo engine. I bought the bell-housing, top-loader, and flywheel/clutch assembly a few years back.
    The clutch is definitely a Hi-Po clutch, but I can't find any casting numbers on the flywheel. The only markings are the letters "Weber" & a "B". Unless someone can chime in with an ID, I'll have to guess that the flywheel is an after-market piece (157 teeth btw)
  • Ray, Unless I am mistaken Weber became McLeod. I appreciate you digging it out for me but I need a factory Hipo flywheel. I have a hipo motor that was sold with out a flywheel. The previous owner unknowingly put an early non hipo flywheel on the it. The internals are correct including the hatchet. The way I see it there should be an imbalance that needs to be corrected. I am willing to listen to opinions if anyone cares to offer one. Dave
