Can someone tell me what engine the following parts go to:
1. Rods 68AE-D
2. Pistons C4OF-61104
Any help appricated.
Gary
1. Rods 68AE-D
Gary
Gary,
Bob Mannel's Small block Ford book only shows casting numbers - so I'm not sure if this will help.
'68 302 rods have a C8OE or C8OE-A cast into the neck.
I didn't see any rods with a number like yours - they all are C#OE or C#AE.
'63-64 HiPo 289 pistons would be marked with a C4OE 6110 ? casting number - the last digit probably varies by lot. Std 289 were cast C4AE 6110 ?. Casting number is down inside the bottom of the piston near the wrist pin area. I didn't see a C4OF casting.
I hope this helps.
Ralph... I sent you an email with pictures. Let me know what you think as soon as possible.
Thanks for your help,
Gary
QuoteCan someone tell me what engine the following parts go to:
1. Rods 68AE-D
2. -Pistons C4OF61104
Gary - Tony (& Marv) list the following:
1. Hipo Rods = C30Z-6200-C part no., C3AE-D casting no. (mine agree with this casting)
2. Pistons = Casting no. C3OZ-6108-L. (Mine were C4-OE6116A before I replaced them with TRW L-2482F pistons. Could it be that our readings were transposed? Note the similarities below: E & F, 0 & 6, 4 & A:
C4 OF61104
C4 OE6116A
Noel,
Story behind this is I am in the process of buying these parts along with a block with caps. The block and caps appear OK according to the pictures I saw. I'm in one state and the parts are in another. So, I have to rely on pictures.
What threw me a curve was the part numbers on the Rods and Pistons. I requested the seller check the numbers again and send them to me. I can see how it would be easy to transpose some numbers and letters, like you said. I think that is the case and all is good. In addition, I requested the number on the rear main. I am told this should be C3OE on a K code and C2OE on a standard 289. Thanks to Fred for giving me this info on the rear main.
Thanks for your input and help,
Gary
