5RO7K258330 Vintage Racer orig drive train also
  • 1965 Kcode HIPO Mustang Vintage Race Car Incudes Numbers Matching Motor & Tranny 5RO7K258330
    5RO7K258330 Door Tag 65A Color M Trim D6 DS072 Axle 5 Trans 5
    RACE ENGINE: 347 Stroker 302 Sportsman Block Forged Steel Crank & Rods, Probe Forged Pistons,
    Main Bearing Girdle, Solid Lifters Crane Cam, AFR Aluminum Heads fully rollerized, Edelbrock dual
    Plane 750 Holley Mechanical Secondaries with Proform Highflow Center Section, Taylor Big 10.4mm
    Wires Stainless Headers Canton 9 quart Oil Pan, K&N Filters & Extreme Airflow Top, Ford Distributorlar
    With Petronix & HEI Top 450 HP, 450 Torque MSD Blaster 3 Coil Power Master High Torque Starter.
    TRANSMISSION: Original Numbers Match, Close Ratio Toploader with new Hurst Competition Plus
    Shifter & Linkage, Ceterforce Clutch with Aluminum Pressure Plate.
    BRAKES FRONT: Kelsey Hayes Calipers with Stainless Braided lines, New Rotors, Hawk Carbon Kevlar Pads ,
    Complete Cobra Automotive Cooling System.
    BRAKES REAR: Ford big Drums New with Segmented Carbo Kevlar Shoes and Complete Cobra Automotive Cooling System
    SUSPENSION FRONT: Global West Upper & Lower Control Arms and Strut Rods with 600 lb Race Springs
    Koni Adjustables. 1 inch Swaybar with Urethane Bushings & Adjustable End Links.
    SUSPENSION REAR: 5 Leaf Racing Springs with Global West Del-Alum bind free Bushing and Shackle Kit
    Under Ride Traction Bars, Spaxs Adjustable Shocks.
    REAR END: Ford Original 9 inch 3.50 Trac Lock with all new Bearings & Seals with remote vent catch tank.
    BODY: Completely Rust Free Body that has not been mutilated or damaged by collision, Shelby Fiberglas Hood Shelby R model front apron, lightened doors with trick latching system, still has all factory paint inside All K code VIN Number Present.
    WHEELS & TIRES: 15 x 7 Torque thrust with Hoosier Street TDS, Cooper SLE Touring Rain Tires New and ARP 200.000LB Studs.
    STEERING: 16.1 Ratio Steering Box with Shelby conversion.
    OTHER: Balanced Racing Drive Shaft with high torque U joints . All stainless lines, Northern Aluminum Rad. Remote oil cooler and oil filter with all braided lines. Aluminum tank crankcase vent system. 25 gallon Fuel Safe fuel cell. All new wiring Autometer carbon fiber gauges with monster tach & shift light.
    Race Safe Halon fire system Fuel Safe discriminator fuel vent system. New Optima deep cycle battery .
    New Holley Blue fuel pump, high flow electric fan, center mounted control panel. Removable steering wheel . Cobra Imola 2 carbon Kevlar Race Seal RCI 5 point harness 2005 date, 6 point rollbar, 48” section rear view mirror, Lakewood driveshaft loop, new fuel pressure regulator, custom 3” X pipe side exit exhaust. Spare set of stainless steel slotted rotors.
    REST OF PACKAGE: Numbers Match HIPO motor complete carb to pan. Original rust free doors, original 4 spd shifter, newly upholstered seats front and rear, all original windows and hardware, 4 repro styled steel wheels with center caps, all headlight buckets and hardware, spare set of original rust free front fenders. Original HIPO air cleaner base with repro top.
    Price $40.000.00US Email bdl_scj@yahoo.com for pics Phone 705 939 1788 between 9 and 5 Eastern Time
    Please be exact with the pics you would like as I am still on dialup and it takes forever to send them.
    Thank You
  • $26,000.00 US for this great car if you want the orig motor and other spares we can talk about that but this is for what is listed in this post.
    1965 Kcode HIPO Mustang Vintage Race Car 5RO7K258330
    Shifter & Linkage, Centerforce Clutch with Aluminum Pressure Plate.
    BRAKES REAR: Ford big Drums New with Segmented Carbon Kevlar Shoes and Complete Cobra Automotive Cooling System
    Koni Adjustable shocks 1 inch Swaybar with Urethane Bushings & Adjustable End Links.
    New Holley Blue fuel pump, high flow electric fan, center mounted control panel. Removable steering wheel . Cobra Imola 2 carbon Kevlar Race Seat RCI 5 point harness 2005 date, 6 point rollbar, 48” section rear view mirror, Lakewood driveshaft loop, new fuel pressure regulator, custom 3” X pipe side exit exhaust. Spare set of stainless steel slotted rotors.
    Call 705 939 1788 Between 9 and 5 Eastern
  • OK guys I need to move this car or the wife is going to remove somthing I would like to keep so the last price drop will be $21,000 US that is less than half what I have in the car .You wont find a better car out there and dont think you will find one cheaper.<BLOCKQUOTE id=quote><font size=1 face="Verdana" id=quote>quote:<hr height=1 noshade id=quote>
  • Just a suggestion here but you might get more response by offering the original engine and selling the race stuff seperately. The race stuff should carry a fair value to other racers.
