1965 Mustang K code coupe. Needs restoration. California car, with original black and yellow plates, has been in dry storage the last 20 years. The glass was taken out and restoration was started. I have new rugs, seat covers and window felts along with 15 X 7 steel style wheels. I was going to keep the motor and part out the car, however, the body is in pretty good condition, and the colors are good on the car. I felt someone else may have the time to restore the vehicle. I currently have too many other projects that I am working on.
Data Plate Decoded as follows: 5R07K139285
Body: 65A 2 Door Hardtop, Standard Interior
Color: 3 Poppy Red
Trim: 26 Black Crinkle Vinyl, Standard Interior
Date: 21J September 21, 1964
D.S.O: 71 Los Angeles
Axle: 8 3.89:1, Conventional
Trans: 5 4-Speed Manual
Engine Details:
Correct Parts:
Carburetor (C4OF AL), Hipo Balancer (4H), Hipo Heads (4G23), Hipo Block (4J21) Hipo Exhaust and, intake manifolds, Hipo Dual point distributor, 1965 hipo motor mounts, Hipo Fan (64H), Hipo Rods. Incorrect alternator, and looks like a roller rocker timing chain was used. Vin is Stamped on Block.
Motor looks like it was rebuilt based on how clean it is and assembly lube over everything. However not a lot of details how or who rebuilt it.
Transmission Details:
4 speed top-loader, wide ratio (RUG-???) Incorrect
Rear end:
1965 Mustang 9” housing with pumpkin correct
Body condition:
Original paint on all body panels, left rear quarter needs 6 hours of work, I would replace tail light panel, Left and Right doors minimal surface rust and small dings, Left and right fenders and hood minimal surface rust and small dings.
Left front floor pan quarter size rust hole. The rest of the floor pans are fine. Front and rear rockers and torque boxes no rust, trunk floor pans clean with minimal surface rust.
Engine compartment clean, no signs of replacement panels, all factory spot welds. All k code VIN’s are intact. Asking Price $13,500.00 Car is sold as is. I have up loaded some pictures, but have more pictures upon request. I can be reached at [email protected]. Car is located in northern California, about 50 miles from San Francisco.
Tim
