• I am looking at a C4OE6015F engine. Mustangtek has this listed as a HIPO block, and unlinke other HIPO blocks (65+), there is no other applcations (other than HIPO) listed. Are all of these blocks HIPO?
  • General theory is that all 5 BOLT HiPo blocks were stamped with a sequential number on the square block boss - drivers side rear of block near where the clutch pivot is. You can find details & photos of this by searching this site.
    Most (but maybe not all) Mustang HiPo blocks were VIN stamped but only if they actually went into a car.
    Not sure if a Fairlane 5 bolt HiPo would have a VIN stamp - but would defintely have a sequential number according to posts here.
    A Service block would probably not have been stamped at all.
    Verifying a TRUE Hipo block is difficult - especially if a sequential number or K code VIN stamp doesn't exist. Regular 289 and HiPo 289 blocks are the same casting - HiPo's were just picked special somehow (no one is 100% sure) and machined with the larger main caps.
    The heavy main caps can be added to any regular 289 block with proper machining. Doesn't make it a ture HiPo block or worth the same money.
  • The same block was used for 2 barrel and 4 barrel engines - only difference is the intake.
    HiPos were only built with 4 barrel intakes.
    Edited once, last by RalphJr (February 19, 2011 at 11:59 AM).
