• I am going to look at a 9" rear end in a 1965 mustang & would like for someone to help me with a few questions.
    1. What is the overall width?
    2. Do all of them have the "step downs"? I was under the impression that some did not have them.
  • Jim, All of them have the step down out towards the bearing end. You should do an advanced search through the forum as there are a lot of posts and pictures on this topic. One of the main things to watch out for are made up housings using 8 inch axle tubes. There is a noticeable step up from the axle tube to the center section where they weld to the center section whereas the proper housing has no step at all.
