Transmission question
  • Is the K code's stock 4 speed transmission a toploader? I assummed it was, but noticed reverse gear is down to the left, whereas the reverse gear in my Cobra replica's toploader is up to the left.
    Walter
  • Hi Walter,
    I assume your Cobra would have a Hurst shifter & linkages? The stock Ford linkages has the reverse to the bottom, Hurst linkages are up beside first.
    Rohan
