What are the part numbers for the proper gears and chain?
Timing chain?
Both crank and cam gear, Im sure theres others out there.
What about the bottom gear with roll pin hole?
Anyone know the number for the crankshaft timing gear?
If you are seeking an NOS Ford crank sprocket, I have one in stock. I have good used ones as well. The camshaft sprocket varies with the build date and change level of your Kar. I have both of them. I also have an NOS Ford timing chain.
I have the sprocket and chain. How much for the crank gear?
