• This 65 Mustang GT Koupe unknown original color with unknown interior is for sale by Ebay seller "The Shop Monkey" with a Buy-It-Now of $18,500.00 or make offer:
    Last project that unfortunately needs to go before I move. It is a 1965 GT originally a 4 speed car. No original drivetrain. Extensive body work has been done and have all the parts listed below. Feel free to ask questions.
    New front disc brakes
    -Calipers
    -Rotors
    New Front Suspension
    -Bearings
    -Coil Springs
    -Coil Spring Perches
    -Sway Bar
    -Upper Control Arms
    -Lower Control Arms
    -Strut Rods and Bushings
    -New Drag Link
    -New Sway Bar End Links and Bushings
    -New Idler Arm
    -New Pitman Arm
    New Door Latches
    New Door Hinges
    New Driver Door
    New Passenger Door
    New Trunk
    New Front Fenders
    New Hood
    New Hood Springs
    New Radiator Support
    New Floor Pans
    New Black Carpet still in the box
    All Welds Seam Sealed
    Fresh Undercoating
    Stiles Sound Deadening Installed
    Parts I have
    Windshield
    Rear Glass
    Door Glass
    Quarter Glass
    Windshield Wiper Arms
    Windshield Wiper motor and Assembly
    Ash Tray and Mount
    Export Brace
    Glove Box Door
    Front and Rear Seats
    Gas Tank
    Tail lights
    Under Dash Wiring Harness
    3 Speed Transmission
    Shifter
    Transmission Mount
    Headliner Bows
    Heater Control
    Shock Tower Mounts
    Front Shocks
    Fuel Tank Filler
    Steering Gear Box
    Kick Panels
    Vent Window Assemblies
    Grille
    Rear Interior Quarter Panels
    Rear Bumper
    Parking Brake Cables and Inside Parking Brake Handle
    Steering Column
    Front and Rear Window Trim
    Has plates and current registration paid to March 2026
    Valspar DTM2004 Sealer/Surfacer/Primer. Ready to be blocked sanded. Zero rust.
    1965 Ford Mustang | eBay
  • This 65 Mustang GT Koupe received no bids by October 29, 2025 and therefore did NOT sell.
  • This Koupe is back on Ebay again by the same seller, which has now been restored with a Buy-It-Now of $39,500.00 or make offer:
    1965 Ford Mustang GT K Code. Does not have the original drivetrain.
    Originally Silver Blue with a 4 speed transmission.
    Door Tag:
    Trim: Black
    Color: Silver Blue
    Date: July 19, 1965
    DSO: LA
    Axle: 3.89
    Trans: 4 Speed
    Just finished the restoration. Everything was taken down to the shell. New floorpans were put in and seam sealed. Sound deadening throughout the car. Car was primed underneath in flat red as the factory would have done it and then the car was painted. Wheel wells and trunk area were also painted body color as the factory would have done. Motor is a freshly rebuilt, period correct 289 with roller cam and lifters, 4 barrel manifold and carb. Transmission is also a period correct C4. Hipo 289 exhaust manifolds and true dual exhaust. Front manual disc brakes with all new brake lines, master cylinder and hardware. Both fender apron VIN numbers match. Has the correct GT mounts under the rear seat and in the trunk. Was originally an A/C car and the original holes in the firewall have been sealed but are available for future use should you decide to reinstall the A/C. It has original front, rear and door glass. Zero rust on the car.
    New on the interior:
    -Carpet
    -Door panels
    -Retro Sound Bluetooth Radio and Speaker
    -Scuff Plates
    -Console
    -Shifter Assembly
    -Dash Pad
    -Headliner
    -Mirror
    -Sun Visors and Brackets
    Glove Box Door
    -Glove Box Insert
    -Heater Box and Register
    -Heater Hoses
    -Heater Core
    -Heater Controls
    -Deluxe Woodgrain Steering Wheel
    -Upholstery
    -Inside Door Handles
    -Outside Door Handles
    -Window Trim
    -Drip Rail Trim
    -Windshield Wipers and Arms
    -Door and Trunk Locks
    -Window Crank Handles
    -Vent Window Assemblies
    -Quarter Window Assemblies
    -All Weatherstrippin
    -Underdash Wiring Harness
    New: Engine & Mechanical
    -Complete Underhood Wiring Harness
    -Steering Box
    -Brake Master Cylinder
    -Front Disc Brakes
    -Rear Drum Brakes
    -Brake Lines
    -Fuel Lines
    -Front Shocks
    -Front Upper Control Arms
    -Radiator
    -Radiator Hoses
    -Transmission Cooing Lines
    -Oil Pressure and Temp Sending Units
    -Plugs and Plug Wires
    -Alternator
    -Battery
    -Starter Solenoid
    -Starter
    -Fog Lights and Harness
    -Carburator
    -Exhaust Manifolds and Full Dual Exhaust with H-Pipe
    -Exhaust Trumpet
    -Turn signals
    -Horns
    -Complete Park Brake Assembly
    New: Exterior
    -Front and Rear Bumpers
    -Grille and Grille Surrounds
    -Fog Lights
    -Emblems
    -Fuel Cap
    -Tail Light Bezels
    -Trunk Mat
    -Tape Stripe
    Refurbished
    -Gauge Cluster
    -All Window Regulators and Tracks
    -Door Hinges
    True mileage unknown
  • This 65 Mustang GT Koupe received no bids by October 20, 2026 and therefore did NOT sell.
  • This 65 Mustang GT Koupe is back on Ebay again by the same seller, which has now been restored with the same Buy-It-Now of $39,500.00 or make offer:
