This 65 Mustang Koupe Black with red standard interior is for sale by Ebay seller "lafontaineclassiccars" with a Buy-It-Now of $49,995.00 or make offer:
K Code HiPo | 4 Speed Manual | Numbers Matching Motor and Transmission | TMI Interior | Stainless Exhaust
This 1965 Ford Mustang coupe was ordered from the factory with a K-code Hi-Po 289ci V8 and a four-speed close-ratio manual transmission, and a 3.50 rear gear ratio! Work included overhauling the engine, transmission, and suspension, fitting the 9 rear end with a replacement limited-slip differential, and refurbishing the cabin with red loop carpeting, a retro-look Bluetooth radio, and TMI Products red vinyl seats. Further equipment includes a Hurst shifter, an Autolite four-barrel carburetor, front disc brakes, and a beautiful American racing 17 wheel and tire package.
The car was delivered from the factory in Vintage Burgundy (X) and was refinished in black under previous ownership. Details include a grille bar, chrome bumpers, dual side mirrors, and finned rocker panel trim, The suspension was overhauled during the refurbishment, and braking is handled by a front disc and rear drum system with a dual-bowl master cylinder.
Inside, refurbishment work included applying sound-deadening material and POR15 beneath the replacement red loop carpets, installing TMI Products red vinyl front bucket and rear bench seats, and fitting a TMI Products removable center console with a Hurst shifter. Appointments consist of a retro-look Bluetooth radio, a storage cubby, and lap belts. The red three-spoke steering wheel frames Rally-Pac-style instrumentation that includes a tachometer and an analog clock fitted below the 120-mph speedometer. The five-digit odometer shows 42k miles, approximately 3k of which were added under current ownership.
The K-code Hi-Po 289ci V8 was overhauled in 2023 and is equipped with a refurbished Autolite 4100 C4GF-E four-barrel carburetor, PerTronix ignition components, a replacement wiring harness, and a chrome-finished air cleaner and valve covers. The engine retains #19 and #21 cylinder heads along with various factory-style chalk and orange markings, and that a period-correct alternator and starter were installed during the refurbishment. The correct HCC AX quick steer box is in the vehicle and the vin is retained on both the engine and transmission!
The warranty number is consistent with a 1965 Mustang coupe that was built in Dearborn, Michigan, and equipped with a K-code 289ci V8. Decoding the trim tag reveals the following information:
Body 65A Coupe with standard interior
Color X Vintage Burgundy paint
Trim 26 Black vinyl with black trim
Date 30K October 30 build date
DSO 24 Jacksonville district sales office
Axle 5 3.50:1 conventional rear axle ratio
Trans 5 Four-speed manual transmission
