66 Mustang GT Converible Raven Black with black pony interior is for sale by Ebay seller "genevaboy" as a reserve price auction with a starting bid of $1.00:
A VERY sought after Vintage Mustang, coming from the second year of the famed Pony car. The “K” in the VIN designates “Factory High Performance” model, which accounts for less than 1% of the Mustang production from 1965 to 1967. A true K-code factory high-performance model.It is powered by a 271hp engine. Finished in its original Raven Black exterior with black interior. It also has the correct steering-column-mounted Rally Pak with the 8,000 rpm tachometer. Get in, hang on & go!
The K-code Mustang is a high-performance version of the Ford Mustang that was produced from 1965 to 1967:
Engine
The K-code Mustang has a 289 cubic-inch V-8 engine with solid lifters, heavy-duty connecting rods, and a high-nodular cast-iron crankshaft. It produces 271 horsepower at 6,000 rpm and 312 lb-ft of torque at 3,400 rpm.
Transmission
The K-code Mustang has a four-speed manual transmission.
Suspension
The K-code Mustang has independent front suspension with unequal length A-arms and coil springs, and a live rear axle with semi-elliptic leaf springs.
Rarity
Less than 1% of the approximately 1.7 million Mustangs produced in the first three years were equipped with K-code engines, resulting in a total production of only 13,214 K-code Mustang
Very desired Raven Black exterior. The car is a GT with pony interior. Interior is as good as exterior. This car should do nothing but go up in value. You will not be disappointed in the conditon of this car.
Note: The only flaw in car is a crack in the steering wheel, clock also works sometimes, but not always (needs a cleaning/oil)
Deposit required which is not refundable. Car can be picked up before March 17 or after March 27. Car is stored in an air conditioned garage.
Inspections welcomed and if you have further question I will give out my phone number if you message me or call Ebay motors
If you want a show car - this is it!
On Mar-08-25 at 14:04:05 PST, seller added the following information:
Mileage on speedometer is 76310
