Hello everyoe,
I'm new to this group and have been a Mustang lover since the first car that I owned, a well-used 64.5 D-code, 4-speed coupe that I bought in February 1967. I knew nothing about Mustangs other than they would be a cool car for a young single guy, but over the next year, I began reading car magazines, learning about Mustangs and Shelby's, and decided that I wanted a fastback with the hi-po engine, and began my search.
I remember looking at a 65 silver hi-po fastback and a 66 GT350 at a Ford dealer, but the fastback wasn't in good enough condition to suit me and the Shelby was out of my price range. A little later, I found a nice 66 base model hi-po coupe at a Dodge dealer and traded in the tired 65 D-code in March 1968. That 66 was a really sweet car, both stock and with the minor mods that I did to it, a Weiand intake, Holley carb and mag style wheels with wide-oval tires.
The 66 coupe got traded in on a slightly used SS454 Chevelle in 1970, and I didn't own another 1st gen Mustang until 1997, when I bought a cosmetically-restored, rust-free 66 hi-po fastback from California. I knew it didn't have a hi-po engine in it when I bought it, but Shelby Parts & Restoration in Green Bay found a 68 service hi-po block and built up an engine with a 302 crank and aftermarket parts. That engine puts down 290 Hp on a chassis dyno (estimated 340 at the crank) and I used the car for Shelby club track events from 1998 up thrugh about 2010, before I retired it in favor of late model Mustangs. I don't plan to ever sell it or restore it to original.
But I do have a non-Ford car with a hi-po 289. A Sunbeam Tiger that I bought in 1972, daily drove it for a year, did an amatuer body restoration, and replaced the stock 260 with a 289 hi-po from a 63 Fairlane. I still have that car today. Now, the only parts from the original hi-po engine are the block, crank, rods, pistons and damper.
Bringing my hi-po journey up to the present, I got to thinking that it would be nice to have a stock hi-po Mustang , like I had back in the late 60's, just to be able to compare how it drives versus my 66 fastback. I don't want a show car, but want something that looks nice and is a solid driver quality.
So, I bought one of the K-code mustangs at the recent Mecum auction through online bidding, not expectng it to have a K-code engine, and find that it doesn't, as I inspected it after its arrival yesterday. It's a late 64.5 car (build date 27G = July 27), but it has a 6-bolt engine that has an intake date 5A29 (January 29, 1965), well into the regular 1965 model year.
Looking under the valve covers, the heads are not hi-po with the cast pockets for the valve springs, but someone has installed screw-in rocker studs, and the heads are attached with ARP bolts. It has a dual point distributor, but the cam apparrently uses the 351 firing order. The cam is hydraulic, since none of the lifterters have the clearance you'd find with a solid cam. I'll need to change the cam to make it run like an original hi-po. I will drop the pan to see what it has for rods. I don't care about date code originality or 6 versus 5 bolt block, I just want it to run like an original hi-po.
I'm convinced that its a genuine K-code car, Its door tag looks original and agrees with the left fender VIN, and I pried the right fender up enough to see the same VIN under the right fender. However, when I took a quick look under the back, it has the non-hi-po differential bumper, and does not have the dual exhaust hanger studs protruding through the wall behind the back seat. So I'm wondering if this is a hi-po car with a non-hipo back end on it. In other words, pieced together from two cars. I'll be investigating this more. The body looks very solid, with no rust damage. The only body shell thing I found obviously repaired is the curved section of the front of the trunk bottom, in front of the fuel tank. There's obvious tack welds holding that curved section in place. I'll remove the back seat and get it up on a lift, to see if I find evidence of grafting on parts to fix a car that has been rear-ended.
More to come when I get it inspected more thoroughly.
New user "65-16 Mustangs"
