• Hi All, I am after some help please. I am missing the axle data tag. I have the correct 9" axle.
    The differential has been taken out of the axle casing and the door data tag shows the axle as an E code, When you decode this it says the axle ratio should be a 3L50 With a model code of WCZ-T.
    The differential with a code E and a 3.50 to 1 ratio should be a limited slip diff. How can I tell if I have got a limited slip diff fitted?
  • External Content www.youtube.com
    Jump to about 1.06 they show an open wheeler when jacked up the rear wheels spin in opposite directions to each other. In an LSD rear end both rear wheels would move in the same direction i.e both forward or both backwards dependant upon the direction you are turning the rear wheel.
