Rebuilt distributor kit
  • Hi,
    I need to rebuilt my Fomoco 67 distributor dual point.
    Which kit I need to buy to do this myself?
    I don’t know if I can use a standard condenser ( condenser fos single point distributor).
    Thanks.
    The condenser for the single point distributor mounts on the end of the condenser where the dual point condenser mounts from the side. The dual points have a higher spring tension than normal points and the single points are different in the way that they mount. There was a Ford kit with all of the pieces "back in the day", but they are long gone. I believe that I have both FoMoCo and Autolite points and condenser in stock if you are trying to go original. They could be shipped with your third member (pumpkin).
