Used 6 Bolt Short Block
  • Here is an Ebay auction for a used 6 bolt .040 over Hipo block by Ebay member "orlandomustang1966" with a Buy-It-Now of 2,400.00:
    • Description: Ford 289 Engine bored .040 over. See Photos for Condition.
    Block – C5AE-6015-E – Date (4L23) – (no VIN stamp)
    Assembly date on oil pan lip: (4L25B)
    Assembly date on front tab: (4L25)
    Crank –302 (2MA) Crank– 0.10 under, possible Brinnel test performed on crank lobe at factory
    302 Rods with 5/16th Bolts
    SpeedPro pistons with forged flat tops
    Dynamically and rotationally balanced
    Machine work performed by Clemmons Speed Shop, Winston Salem, NC
    Ford Engine 289 Hi-Po Block .040 Over C5AE-6015-E Main Caps | eBay
  • Hi Fred.
    What about connecting rods with 5/16 bolts?
    Should be 3/8 bolts?
    So is it a true HiPo block?
    Thanks.
    Being as it has the correct main caps, it may possibly be a Hipo block. The seller actually did not advertise it as a Hipo short block but rather a Hipo block, I corrected that in the forum. It has a 302 crank and rods which are definitely NOT Hipo 289 items.
  • This listing was ended by the seller December 21, 2014 with the following explanation "there was an error in the listing".
