• Here is an Ebay auction for a used Tri Power Setup by Ebay member "jorbli_4" with a starting bid of $3,500.00 and Buy-It-Now of $5,000.00:
    289 hipo intake with 3 2 barrel holly carbs And Breather Complete With Fuel Rail.
    289 hipo intake with 3 2 barrel holly carbs And Breather Complete With Fuel Rail | eBay
    This setup has the wrong air cleaner top.
  • This used Tri Power Setup received no bids by August 21, 2022 and therefore did NOT sell.
  • This used Tri Power Setup is back on Ebay again with a new lower starting bid of $3,000.00 and the same Buy-It-Now of $5,000.00:
  • Here is an Ebay auction for a used Tri Power Setup by Ebay member "chras_92" with a Buy-It-Now of $2,800.00 or make offer:
    289 Ford, 3 - 2 Barrel Carburators.
    289 Ford, 3 - 2 Barrel Carburators | eBay
    Yes Allen, this is another wrong air cleaner. A bidder on this setup really needs to do their due diligence on this one as there are a lot of issues.
  • Here is an Ebay auction for a used Tri Power Setup by Ebay member "classiccarsandjeepparts" with a Buy-It-Now of $2,650.00:
    Original OEM in Good Overall Condition Pulled off Original K Code 289 Shelby.
    Shelby was Running when Taken Off.
    Great OEM Part to Finish your Shelby or Shelby Replica Build.
    1965 Mustang 289 FoMoCo OEM Induction System w/3 Two Barrel Carburetors | eBay
  • This used Tri Power Setup received no bids by August 28, 2022 and therefore did NOT sell.
  • This used Tri Power Setup is back on Ebay again with a new much lower starting bid of $2,000.00 and a new lower Buy-It-Now of $3,500.00:
  • This used Tri Power Setup received no bids by September 4, 2022 and therefore did NOT sell.
  • This used Tri Power Setup is back on Ebay again with a new lower starting bid of $1,800.00 and a new much lower Buy-It-Now of $2,750.00:
  • This used Tri Power Setup sold September 12, 2022 on Ebay for $1,800.00.
  • Here is an Ebay auction for a used Tri Power Setup by Ebay member "ludemilla" with a Buy-It-Now of $1,200.00:
    This is a complete tri-power set up for Ford small block , 289/302 . I ran this set up in my 51 Ford custom with 302 and AOD Trans for a couple years. I did not run the two outboard carbs , ran super good with just the center carb. Mainly because I didn't have the expertise to get the out two outer carbs to function very well. Plus my stock 302 was NOT a hipo engine , so I just think I was over carbureted when those other two carbs would kick in.
    Anyway , the car always started and ran very smoothly on just that center carb.
    These carbs are Not Holley 2bbls. They are just Ford stock 2100 2bbls, with the top horn cut down so they nest together nicely on the tri-carb manifold. Used tri-carb linkage from SPEEDWAY and the fuel log from JEGS. I HAD THE MANIFOLD AND AIR CLEANER POWDER COATED.
    I am getting the 51 Ford ready to sell, so didn't want to let this set up go with the car. Put the stock 2100 single 2bbl set up back on this engine.
    please message me with any questions you have.
    Ford 289/302 Tri-carb manifold , carbs , air cleaner fuel log , linkage | eBay
  • Interesting modifications to the 2100 carburetors for the fuel inlets. Yes Allen, this air cleaner is incorrect.
  • This used Tri Power Setup sold October 5, 2022 on Ebay for $1,200.00.
  • Here is an Ebay auction for a used Tri Power Setup by Ebay member "jellisfeingold" with a starting bid of $1,900.00 and Buy-It-Now of $2,500.00:
    This is a vintage and very original 289 tri-power intake kit as listed in the 1964-65 Ford Performance Catalog.
    Made for the small block
    Shelby Cobra, Mustang, Falcon, and Fairlane.
    Ford only installed triple 2-barrel carb setups on some late-50s and early-60s 390/406 big block/FE Thunderbirds and Galaxies. No 3x2 carb kits were factory-installed on any 260/289 engine cars. Instead, beginning in 1964, Ford dealers sold these small block tri-power kits over-the-counter at the parts desk through its Ford Performance parts program. Ford had just cut ties with Holman-Moody, in favor of Carroll Shelby, who encouraged them to enter the performance field, resulting in the Ford Performance Parts catalog. The original catalog offerings included many Shelby sourced and selected items, such as cams, manifolds, valve covers, etc. The performance parts program was slated to go online so quickly that Ford had to outsource the intake manifold casting to Buddy Bar Casting, in LA. Later castings were by branded Ford (or COBRA) with cast-in logos and the V8 firing order. The early Buddy Bar manifolds like this one are super rare, and beautiful. These performance catalog items, including 3x2 and dual quad carb kits, were aimed squarely at 260/289 Shelby Cobra, Mustang, Falcon, and Fairlane owners. These small block triple carb sets, especially as compete as this one, are exceedingly rare.
    This triple-deuce setup was in recent use (see video) in my ‘63 Ford Falcon Futura. I'm restoring the car, and its 289 engine is unoriginal, so it's being replaced by a factory-correct (and way lower performance) 2-barrel carb 260 cu. in. engine.
    This kit has awesome looks and incredible sound. On the progressive linkage the two outer carbs come on at about 40% throttle, and it takes off like a rocket.
    This vintage tri-power kit includes:
    • Original Ford Performance/Buddy Bar manifold (dated 8/64), with original underside baffle
    •  3 vintage Holley 2-barrel #2300 carburetors, List #2436/2868. The two end carbs are dated 4/64, and the primary FE carb has a new choke mechanism installed
    • Original Ford Performance cast aluminum air filter housing
    • New correct progressive linkage
    • New throttle linkage bell-crank
    • Original Ford Performance fuel log
    • Recent air filter element
    • New Holley choke mechanism on the center/primary carb
    • Fresh gaskets, idle jet seals, and new needle valves (installed)
    Although recently in use, the carbs should be checked over and refreshed.
    Vintage Ford 289 Small Block Tri-power Intake - Complete kit | eBay
  • This used Tri Power Setup sold October 22, 2022 on Ebay for $2,500.00 with 2 bids from 2 bidders.
  • Here is an Ebay auction for a used Tri Power Setup by Ebay member "speedway_carburetors" with a Buy-It-Now of $2,200.00 or make offer:
    Offered is an original Ford 289 tripower setup for the Mustang, Shelby and Cobra vehicles. This is one of the performance induction systems Ford offered over the counter. This is a date matched setup with an original Buddy Bar intake manifold. Includes everything you see in the photos. Throttle shaft moves freely and the carbs are excellent candidates for restoration. Two of the intake studs need to be drilled and re-tapped.
    This unit has been sitting on a shelf in a garage for many years. It is in typical barn find condition but is well preserved and a great find.
    Center Carb
    C4AF-9510-U Holley List-2881 Date Code: 502
    Outer Carbs
    C4AF-9510-V Holley List-2882 Date Code: 502
    This induction system is a great foundation for a complete restoration. Fuel log, some linkage parts and choke parts will need to be located to complete. Does not include air cleaner assembly.
    Ford Mustang Shelby 289 3x2 Tripower Intake & Carburetor Assembly C4DZ-6B068-B | eBay
  • This used Tri Power Setup sold December 10, 2022 on Ebay for $2,200.00.
