Used 6 Bolt Hipo Engine
    • Official Post
    Here is an Ebay auction for a used 6 bolt Hipo engine by Ebay member "bradsstuffcarsbmxandmore" with a Buy-It-Now of $8,500.00:
    ford 289 hipo engine long block assembly. Block standard bore just magna-fluxed bake blasted heads un-ported un-milled magna- fluxed clean bake blasted standard crank un-turned polished journals pistons rods standard Hi Po balanced and crank slinger not pictured is the flywheel looks to have been balanced at one time valves springs will assemble if necessary block has taper towards the top of the cylinders but no visible ridge this is a Ford Service block date code casting is C8 top of the heads 289 bottom has 302 cast 20 and 21 on the bottom of the heads was running when removed customer went to a larger displacement more HP set-up ... Thank you Brad
    ford 289 hipo engine long block assembly | eBay
    This engine is based off of a Mexican block with C8ZE replacement Hipo heads. It has a C8ZE replacement Hipo balancer. The rest of the pieces are unknown but appear to be correct.
    • Official Post
    The seller ended the listing July 4, 2022 with the following explanation "This listing was ended by the seller because the item is no longer available".
    • Official Post
    Here is an Ebay auction for a used 6 bolt Hipo engine by Ebay member "old-dixie-highway" with a Buy-It-Now of 14,995.00 or make offer:
    Genuine 1965 K Code engine. Recent rebuild .30 over. Pulled from a genuine K Code Mustang Coupe in another auciton. Dont have time to work on it, so we are offering the engine and car separately but can sell both together for a fraction of the $63,000 value NADA Guides has on a completed HIPO car.
    Fresh oil. Has 2 sets of heads. Will include a set of 302 heads that this engine was mated with but has the original 289 heads. 1M on the crankshaft. Has the damper and intake althought not seen. Will assemble everything together shortly...but its all there.
    Dont spend $11,000 on a HIPO Clone when you can get the real deal for $14,995 obo
    Call with questions.
    REAL K Code HIPO 289 engine/heads. Bored .30 over. Dont spend $11k on a clone | eBay
    • Official Post
    This used 6 bolt Hipo engine by Ebay member "mustangmasters428" is back on Ebay again with the same starting bid of $7,500.00:
    1965 Mustang 289 Hipo Motor Hipo 289 K Code Fairlane GT 350 High Performance 289 | eBay
    All of the issues mentioned previously when first listed on Ebay, remain the same.
    • Official Post
    This used 6 bolt Hipo engine sold July 30, 2022 for $6,400.00.
  • This used 6 bolt Hipo engine received no bids by July 31, 2022 and therefore did NOT sell.
  • The sale of this engine must have actually not happened. This Ebay auction for a used 6 bolt Hipo engine by Ebay member "bradsstuffcarsbmxandmore" is back with a new lower Buy-It-Now of $6,400.00 or make offer:
  • Make sure to carefully read the description as this engine is based off of a Mexican block with C8ZE replacement Hipo heads. It has a C8ZE replacement Hipo balancer. The rest of the pieces are unknown but appear to be correct.
  • This used 6 bolt Hipo engine by Ebay member "mustangmasters428" is back on Ebay again with the same starting bid of $7,500.00:
  • This used 6 bolt Hipo engine received no bids by August 28, 2022 and therefore did NOT sell.
  • This used 6 bolt Hipo engine received no bids by October 16, 2022 and therefore did NOT sell.
  • This used 6 bolt Hipo engine received no bids by November 20, 2022 and therefore did NOT sell.
  • The listing for this used 6 bolt Hipo engine was ended by the seller November 20, 2022 with the following explanation "This listing was ended by the seller because the item is no longer available".
  • This used 6 bolt Hipo engine received no bids by December 11, 2022 and therefore did NOT sell.
  • This used 6 bolt Hipo engine received no bids by December 25, 2022 and therefore did NOT sell.
  • Here is an Ebay auction for a used 6 bolt Hipo engine by Ebay member "orlandomustang1966" with a Buy-It-Now of 9,500.00 or make offer:
    • Description: Used original 1965 Ford Mustang 289K Hi-Po Engine. Included items are Ford C5AE-6015-E Block, Heads with matching dates (4G9), Rear Balancer, Cookie Cutter, and Cam Shaft. See Photos for Condition.
    • Fits year(s): 1965-1967
    • Models: Ford Mustang
    • Engine: 289K Hi-Po
    • Ford Part # C5AE-6015-E
    • Date Code: (4G9) on both heads
    • Block Date: (4G17)
    • Bore: STANDARD
    • Condition: Used
    • Tested: NO
    65-67 Ford Mustang 289K Engine Heads Block Cam Hi-Po Balancer C5AE-6015-E #5263 | eBay
