5F08K309477 on Ebay NIR
  • 65 Mustang convertible is for sale by Ebay seller "vanguardmotorsales" with a Buy-It-Now of $99,900.00:
    1965 Ford Mustang Convertible
    VIN: 5F08K309477
    Check out this gorgeous 1965 Ford Mustang Convertible! This Mustang is a factory K-Code car and it's sporting a glossy Black Exterior Paint finish, Manual Convertible Top, Black Interior, 15'' Magnum 500 Wheels, BFGoodrich Radial T/A Tires, Chrome Bumpers, Polished Trim, and a Dual Exhaust System! The previous owner of this Mustang let us know that his father actually purchased this Ford back in the 80's. He would ride around in this '65 with his dad, creating lasting memories. After cruising it around for a few decades, his father decided to bring this Mustang back to life with a complete Nut and Bolt Restoration that was done by local experts here in the Metro-Detroit area! After it's completion, this Ford was passed down through the family, while also being meticulously cared for! Under the hood sits a Ford 289ci Hi-Po V8 Engine with an Autolite 4-Barrel Carburetor sitting on top. Power is sent to the rear tires through a Toploader 4-Speed Manual Transmission and a Ford 9'' Rear End with approximately 3.89:1 Gears and Limited Slip. This Ford is also equipped with Manual Steering and Manual Front Disc Brakes with Kelsey Hayes 4-Piston Calipers.
    The interior of this Mustang was wonderfully restored and it's in terrific condition! Take a look inside to see this Ford sporting Front Bucket Seating, Rear Bench Seating, Black Vinyl Upholstery throughout, Black Carpeting and Floor Mats, 3-Point Steering Wheel, Factory Dashboard Gauges and Rally Pac Gauges, Aftermarket AM/FM Radio and Speakers, Center Console, Floor Shifter, and a Spare Tire that's located in the trunk. The undercarriage of this Mustang looks incredible like the rest of the car! Take a look underneath to see the nice condition of the Frame Members, Torque Boxes, Floorboards, Pinch Welds, Rocker Panels, New Fuel Tank, Fuel Lines, Brake Lines with an Adjustable Proportioning Valve, Brakes all around, Complete Drivetrain, Steering Components, Independent Front Suspension, Leaf Spring Rear Suspension, along with the New Dual Exhaust System that's fitted with Factory Replacement Mufflers!
    This 1965 Ford Mustang Convertible is a beautiful classic that's ready for your local car show or cruise! Traveling along with this Ford is a photocopy of the original window sticker and various component manuals. Any collector or enthusiast would love to own this Mustang and it won't last long! Call us today before it's gone!
    Call us today and let VMS park your dream in your driveway! 248-974-9513
    Go to http://www.vanguardmotorsales.com to see over 100 HD photos and our in-depth video for this and 1965 Ford Mustang Convertible over 200 other classics!
    Mechanics:
    Engine # C5AE - 6015E
    - Engine has a Mechanical Only Advanced Distributor, Correct for Hi-Po Applications
    - Large Pulley Alternator (Correct for Hi-Po)
    - Engine also has Large Balancer, Correct for Hi-Po Applications
    - Block Casting Date: 5C18 (March/18th/1965)
    - Car was Born Oct/1964
    Serial # 5C19F
    Stock Cylinder Heads
    - Valve Covers Removed to Confirm:
    Hi-Po Correct Screw-In Rocker Studs
    Looks to have Factory Head Bolts and Valve Seals
    New Single Springs with Dampers
    OEM Rockers and Pushrods
    - Casting Date: Jan/11th/1965
    - Carb #: C40F AL
    - Venturi Size: 1.12
    - Carb also has a Manual Choke, Correct for Hi-Po Applications
    Transmission # HEH BX 024038
    - Casting #: C5AR 7006 - D
    - Tag Information Tells Us it is 289 Hi-Po Specific and a Close-Ratio Transmission
    Front Suspension - Independent
    Rear Suspension - Leaf Spring
    Ford 9" Rear End
    - Ratio: Approximately 3.89:1
    - Limited Slip
    - Casting Date of 3rd Member: 6J7 (9/7/1966)
    - Rear End is Not Original to the Car but it has the Correct Gear Ratio
    Front Wheels - 15"
    Rear Wheels - 15"
    Front Tires - 205/60R15
    Rear Tires - 245/60R15
    Front Brakes - Disc
    Rear Brakes - Drum
    - Front Disc Brakes are Early Ford Kelsey Hayes with 4-Piston Calipers
    Manual Steering
    Dual Exhaust
    - Correct Cast Iron Hi-Po Exhaust Manifolds
    - Factory Replacement Mufflers
    Body:
    - Paint is Phenomenal
    - Chrome looks Great
    - Upgraded Headlights
    - Emblems are in Good Condition
    - Doors and Trunk Operate Smoothly
    - Taillight Trim in Great Shape
    - Bumpers are Clean
    Interior:
    - Door Jambs are Clean
    - Center Console
    - 4-Speed Shifter
    - Carpet is Clean
    - Dash is in Great Shape
    - Aftermarket Radio
    - Gauges are Clean
    - Front and Rear Seat Belts
    - Spare Tire in the Trunk
    Underneath:
    - Gas Tank is New
    - Exhaust is New
    - Paint looks Great
    - Floorboards are Solid
    - Frame is Solid
    - Front Crossmember is in Good Shape
    - Rockers are Solid
    Don't miss out! Call Tom 7 days a week! 248-974-9513
    [email protected]
    1965 Ford Mustang Convertible K-Code | eBay
  • C6ZZKGT June 28, 2021 at 10:50 PM
    Changed the title of the thread from “5F08K309477on Ebay NIR” to “5F08K309477 on Ebay NIR”.
  • This 65 Mustang convertible received no bids by June 30, 2021 and therefore did NOT sell.
  • This 65 Mustang convertible is back on Ebay again with no changes:
  • This 65 Mustang convertible received no bids by July 8, 2021 and therefore did NOT sell.
  • This 65 Mustang convertible is back on Ebay again with a Buy-It-Now of $99,900.00 or make offer:
  • This 65 Mustang convertible received no bids by July 15, 2021 and therefore did NOT sell.
  • This 65 Mustang convertible received no bids by July 23, 2021 and therefore did NOT sell.
  • This 65 Mustang convertible received no bids by July 30, 2021 and therefore did NOT sell.
  • This 65 Mustang convertible received no bids by August 6, 2021 and therefore did NOT sell.
  • This 65 Mustang convertible received no bids by August 14, 2021 and therefore did NOT sell.
  • This 65 Mustang convertible received no bids by August 23, 2021 and therefore did NOT sell.
  • The listing for this 65 Mustang convertible was ended by the seller August 29, 2021 with the following explanation "This listing was ended by the seller because the item is no longer available".
