5F07K375863 on Ebay
    • Official Post
    65 Mustang Koupe Ivy Green with Palamino interior is for sale by Ebay seller "stlouiscarmuseum " with a Buy-It-Now of $49,900.00 or make offer:
    For those of you who are unaware, this infamous "K-code" designation is a very tough option to find in any of the 1.8 million Mustangs produced from 1965-1967. In fact, only 7,273 Mustangs received this K-code 289ci performance variant in the 1965 production year. To put that into perspective, just 1.1% of all Mustangs built in 1965 were K-codes. It would also be the exact vehicle selected by road racer, Carroll Shelby, as his platform vehicle to build his legendary GT350! The option included a solid lifter 289ci V8 with aluminum flat-top pistons, heavy duty connecting rods, larger rod bolts, nodular cast iron crankshaft with larger counterbalance for higher rpm's, dual point distributor, special Autolite carburetion and header type manifolds with H-pipe dual exhaust. These combined components produced an incredible 271 horsepower at 6,000rpm! If selected, it would be the most expensive individual option on the sales order which came standard with special geared top loader 4-speed manual transmission, larger 9" rear axle, and Special Handling Package to provide stiffer springs, shocks, and front stabilizer bar! It was a brutish factory powertrain and could not be combined with power steering, power disc brakes, or air conditioning. A weekend racer's delight!
    We are quite excited to offer this beautifully documented 1965 Ford Mustang K-code Coupe finished in stunning Ivy Green Metallic® over Palomino Vinyl interior (29)! Features on this car include correct, number matching 289ci V8 Hi-Po engine, 4-speed close-ratio manual transmission, original 9" rear end housing a 3.50:1 gear ratio, upgraded 14" American Racing wheels wrapped in BF Goodrich Radial T/A tires, R-Model center caps, Visibility Group (Remote driver mirror, interior Day/Night mirror, & 2 speed wipers with windshield washer), Accent Group (rocker trim moldings), original AM radio, tinted glass, back-up lamps, carpeted floor mats with embossed logo, and aftermarket SunPro tachometer along with AutoMeter under dash oil & water temp gauges to better monitor the engine vitals!
    This entire car was restored mechanically between 2007-2009 while under ownership with a professional pilot based in Mesa, Colorado. The list of new and reconditioned parts is far too long to list everything in this description, so it will come with a large binder full of receipts. The factory engine was completely overhauled by Top End Performance in Grand Junction, CO by owner Vance Wilson in June 2009 at 85,340 miles on the odometer. It received the full treatment being lined cleaned, line-honed, smoothed mating surfaces, balanced crank, recondition rods with ARP bolts, new pistons, heads ported fitted with Ferrea racing intake & exhaust valves, roller cam & rockers installed; rebuilt transmission, resurfaced flywheel, new clutch kit, Edelbrock Victor Series aluminum water pump, Northern performance radiator, new hoses, belts, fluids, etc. A set of photos is included documenting this service. Even the rear axle would get treated to a completely rebuild and conversion to a Traction-Lok set up! It would be dyno-tuned in-house to achieve 302hp/320 lb. ft of torque on 85 octane pump gas! We estimate it has more to offer now back in low land conditions!
    The entire suspension system was rebuilt in July 2009 with upper & lower control arms, inner & outer tie rods, Grabatrak shocks & springs, idler arm, shackle kit, all bushings, etc. A new exhaust system with Flowmaster mufflers along with further upgrades throughout 2013 included blueprinted distributor by Distributor Dynamics, custom built Holley 680cfm carb by Boulevard Automotive, electric fuel pump, Chris Alston's Chassis Works Total Control Products hardtop subframe connectors, center support with driveshaft safety loop. It will come with two sets of wheels/tires.
    Our Mustang K-code would travel with the same owner to California and receive an impressive professional repaint in March 2014 by Lakeville Autobody & Paint in Petaluma, CA. It then received an all-new interior in October 2014 by Mustangs, Muscles & Classics of Santa Rosa, CA to include headliner, seat upholstery & foams, seat tracks, carpet & underlayment, door panels, arm rests, dash pad, mirror, steering wheel, horn ring, weather stripping & exterior moldings, trim & emblems, door sill plates, door & trunk locks, and more!
    All drivetrain identification tags are present including a clear VIN stamp on the block itself! Additional documentation includes original dealer sales order dated October 1964, original window sticker, original owner's manual with original dealer and ownership details, factory warranty card, copy of the original title & future owner's thereafter, Ford Performance Tips from Ak Miller's Cobra Kit catalog, and a signed letter by Ak Miller to the original owner in a reply regarding the proper oil to use in his Mustang. All super hard to find documentation on any Mustang K-code! It now shows 89,943 miles on the odometer. It is a superbly rare car, exceptionally fast, and beautifully presented! It's something to be truly proud of on and off the road! Please feel free to call with any questions!
    The engine block bares correct Hi-Po cast number C5AE-6015E with 6-bolt bell housing. It retains its original cast iron heads (#19 & #21), original harmonic balancer, original solid lifter camshaft, original 4-blade cooling fan, Shelby Cobra aluminum intake manifold (S2MS-9424A), custom exhaust headers by FPA, Mallory Unilite HEI distributor (original FOMOCO dual point/centrifugal advance distributor included), original style air cleaner, original motor mounts, Holley carburetor (concours restored original Autolite 4100 carburetor C50F-J with manual choke included) and export support brace. The transmission and 9" rear end are date-code original to this Hi-Po Mustang.
    1965 Ford Mustang K-code Coupe | eBay
    • Official Post
    With all of the pictures, I am surprised that there are none of the undercarriage or door tag. This is a good day two Kar and a fair ways from totally original. It is a shame to hear about all of the changed suspension and springs as original stuff is getting really tough to find (expensive).
  • The listing for this 65 Mustang Koupe was ended by the seller May 12, 2021 with the following explanation "This listing was ended by the seller because the item is no longer available".
