Used Hipo Crankshaft
  • Here is an Ebay auction for a used Hipo crankshaft by Ebay member "falconfutura1965" with a Buy-It-Now of $600.00:
    289 Hipo Crankshaft. Condition is "Used". Please! I don't have any other hipo parts for sale at this time.. This Crankshaft was removed from an early 65 5 bolt block that was deemed beyond reasonable repair. It was cleaned magnafluxed and machined to .010 mains and rods undersize. There are a few minor inclusions that would clean up at .020 but my machinist assured me it would be in more than fine . This is a legit hipo crank that still has the orange marking . See photos of engine before crank was removed. It's not beautiful because I refrained from bead blasting it in order to retain the original hipo paint markings.. This auction is for Crankshaft only but also Includes hatchet weight and timing gear...
    289 Ford Hipo Crankshaft | eBay
    The listing for this used Hipo crankshaft was ended by the seller December 4, 2020 with the following explanation "This listing was ended by the seller because the item is no longer available".
  • Here is an Ebay auction for a used Hipo crankshaft by Ebay member "bobmannel" with a starting bid of $500.00:
    This crankshaft came out of a 289 HiPo K-code 1963 Fairlane with 94,000 miles. The car was last registered in 1976, then sat in a field for 4 years, then another 4 years in a barn. Engine was disassembled in 1984, crankshaft photographed, then carefully stored. So, crankshaft is pretty much like it was when removed. As can be seen, the journals are oil stained from sitting for so long in the same place. The journals are actually in remarkably good condition. With a good cleaning and polishing, crankshaft likely could be run in standard size. But, it would clean up like new if journals turned 10 thousandths under. The critical distinguishing feature of the 289 HiPo crankshaft was the orange paint on the aft center counterweight, which is still clearly visible in spite of the oil staining. These crankshafts were made of high nodularity cast iron. To check nodularity, Ford polished the rear counterweight so that a microscope could be used to compare the spherical nodules against go/no go photos. Only 289 HiPo crankshafts in the early years had this polished counterweight. I also photographed all the markings/stampings, but they have little meaning. The 1M was used for the molds of all Ford small block V8 crankshafts at the time. I show all the main and connecting rod journals. What looks like rust are oil stains. In the last picture I show the oil seal surface, which looks like it has rust, but a gentle scraping (see arrows of the same place), shows it is just build up of oil residue. Under it, the machine lines on the oil seal surface are clearly visible. Rarely will you find a 289 HiPo crankshaft in as good a condition as this one.
    Will only ship to the 48 contiguous states.
    1963 289 HiPo Original Crankshaft standard size in good condition | eBay
  • Here is an Ebay auction for a used Hipo crankshaft with counterweight and crank gear by Ebay member "COBRANDA" with a starting bid of $1,000.00:
    1965 - 1967 MUSTANG K-CODE HIPO
    1965 - 1967 SHELBY GT350
    POSSIBLE NOS, BUT BEING SOLD as ORIGINAL/USED
    K-CODE 289 HIPO V8 ENGINE
    CRANKSHAFT w/. COUNTERWEIGHT & HIPO GEAR
    A NICE ORIGINAL FORD CRANKSHAFT: 1965-67
    MUSTANG & SHELBY K-CODE 289 HIPO V8
    CRANKSHAFT w/. COUNTERWEIGHT & GEAR
    FORD PART#:
    C3OZ-6303-B
    FOR the K-CODE 289 HIPO V8 ENGINES
    STEEL CRANKSHAFT
    INCLUDES COUNTERWEIGHT
    the HIPO SPECIFIC GEAR
    THIS CRANKSHAFT has the BRINNELL TEST
    CUT on the 1 AREA
    ...see pics!!!
    NOTE:
    THIS COULD BE A POSSIBLE NOS PIECE
    but IS BEING SOLD as a ORIGINAL-USED PIECE
    NO SIGNS of WEAR &
    there is FORD's COSMOLINE of the CRANK
    ...see pics!!!
    THIS ORIGINAL FORD CRANKSHAFT: 1965-67 MUSTANG & SHELBY GT350
    K-CODE 289 HIPO V8 CRANKSHAFT w/. COUNTERWEIGHT & GEAR PICTURED,
    IS the ORIGINAL FORD: 1965-67 K-CODE HIPO CRANKSHAFT you WILL RECEIVE
    1965-67 Mustang & Shelby Original 289 HIPO V8 Crankshaft w/ Counterweight | eBay
    This used Hipo crankshaft sold March 4, 2025 on Ebay for $950.00 with 10 bids by 5 bidders.
  • This used Hipo crankshaft with counterweight and crank gear received no bids by March 11, 2025 and therefore did NOT sell.
  • This used Hipo crankshaft with counterweight and crank gear is back on Ebay again as a Buy-It-Now of $1,500.00:
  • This used Hipo crankshaft and crank gear sold March 12, 2025 on Ebay for $1,500.00.
