5F09K385400 on Ebay
  • Here is a 65 K code fastback listed on Ebay by seller "sto-1867" with a starting bid of $25,000.00:
    1965 Mustang, K-Code HIPO 289 Fastback, GT, rebuilt Ford Toploader 4-speed, Hurst Competition Plus, numbers matching block (C5AE-6015-A), 1965-stamped cylinder heads, disc brakes, adjustable proportioning valve, Ford 9 inch rear, 3.50:1 Auburn limited slip, car initially restored at Salters Mustangs (Pace, FL), new floor pans, new frame rail extensions, engine rebuilt/upgraded 22,800 miles ago, fabricated and painted as GT-350 replica, Wimbledon White with Guardsman Blue stripes, sourced some Shelby OEM parts (springs, traction bars, etc), everything replaced or rebuilt, new gas tank, new sending unit, 5/16 stainless fuel lines, correct K-Code double-spring fuel pump with canister filter, new Holley 600 double-pumper, Tri-Y headers, Flowmaster exhaust, extensive documentation dating back to 1965, owned for 24 + years, less than 1% of '65s were K-Code, not too many left, can't be told from real $350,000+ Shelby and will outrun the 306 HP GT-350, HIPO SBF built to be bulletproof to 7,000 RPM, Modine 4-core radiator (runs cool), 190,000 psi ARP rod bolts, balanced rotating assembly, .534 lift Competition Cam, roller rockers, built right, looks right and runs right, five (5) American Racing Torque Thrust, BFG 225/60 x 15, custom one-off Shelby center caps, extensive documentation including copy of original FOMOCO Certificate of Origin, a wall full of trophies! When purchased in 1995, car showed 78,000 miles (mileage exempt) which I think was correct! Later, speedometer repaired and turned back to zero! Now, showing 22,874 miles! This is the real deal, not a rustang! Good cars are not cheap; cheap cars are not good! Will regret selling this one because I can not replace it! Clear title! Payment required by certified (cashiers) check or electronic wire transfer (EWT) (no cash)! $500 "non-refundable" deposit required forty-eight (48) hours after auction end (to be credited upon sale); full payment required within seven (7) days after auction end! Shipping responsibility of buyer (will help coordinate pick-up)! Check or EWT must clear my bank before car and title conveyed! The car is located in northwest Florida! (Panhandle) (850) 651-8785.
    On Jul-15-20 at 02:31:12 PDT, seller added the following information:
    FOR SOME REASON, EBAY LISTED MY CAR TWICE! THIS IS THE CORRECT LISTING! I HAVE BEEN TRYING TO GET LISTING #283939206720 REMOVED BUT, EBAY HAS MADE IT IMPOSSIBLE TO CONTACT A REAL PERSON! I KEEP GETTING AN ELECTRONIC DIGITAL VOICE IN CUSTOMER SERVICE WITH NO WAY TO EXPLAIN THE ISSUE AND RESOLVE THE PROBLEM!
    https://www.ebay.com/itm/1965-Ford-…m4383.l4275.c10
  • This 65 K code fastback sold July 20, 2020 on Ebay for $65,099.99 with 16 bids from 5 bidders.
  • This 65 K code fastback GT350 clone is back on Ebay again with a new seller "rsche78" with a starting bid of $40,000.00 and a Buy-It-Now of $68,000.00:
    This 1965 Ford Mustang Shelby GT is a restomod original K code that the current owner has had for 5 years. The vehicle runs great and is mainly used for car shows. It features a clean title and 99000 miles on the odometer. The car is finished in a striking white color and is sure to turn heads wherever it goes.
    Vehicle Details
    Very nice car. Not a trailer queen but a super nice car. A real head turner!
    Could not find any numbers on block so I doubt it to be numbers matching. Don’t drive it as much as I would like and figured it should move on to a new home!
    Exterior
    1965 mustang gt350 fastback clone. 289 v8, Lincoln rear end, 4 wheel disc brake, running driving perfectly.
    1965 Ford Mustang | eBay
  • This 65 K code fastback sold February 17, 2025 on Ebay for $57,000.00 with 29 bids from 3 bidders.
  • This 65 K code fastback GT350 clone apparently did NOT sell and it is back on Ebay again with the same seller "rsche78" with a starting bid of $40,000.00 and a Buy-It-Now of $68,000.00:
    Vehicle Details
  • The listing this 65 K code fastback GT350 clone was ended by the seller February 26, 2025 with the following explanation "this item is no longer available".
