Used Weber Setup on Unknown Intake Manifold
    • Official Post
    This used Weber setup and intake intake manifold is for sale by Ebay seller "columbo14 " with a Buy-It-Now of $2,500.00:
    Vintage Weber 8-Stack Set for Small Block Windsor Ford
    ~ Genuine Weber 44-IDF Carburetors Made in Italy.
    ~ Bought new as a complete set.
    ~ Properly tuned to its engine. (Never had to mess with them afterward).
    ~ As removed from running / driving modified HiPo 289.
    ~ Street driven 33K miles.(Mostly leaded V/P was used).
    ~ All fuel and air filters were well maintained.
    ~ Sold car as a roller. They have been in proper dry storage since.
    ~ Custom made 1” aluminum spacers.(Needed to clear stock valve covers with their own set of spacers).
    ~ Bell-Crank linkage is complete and operates smoothly.
    ~ Manifold has a threaded boss for a cable bracket. (That is not included).
    ~ Aeroquip / K&N /Arp / Correct low fuel pressure gauge. (Carbs only need 2 / 3 lbs. pressure).
    ~ Manifold was ported and bench flowed. (Approx. 1.25" wide x 2.00” high ports).
    ~ Mounting holes have been elongated a bit for milled heads & with intake studs.(flat washers cover).
    ~ Port runners are drilled / tapped for external Nitrous or DMV required pollution pcv emissions if needed.
    ~ Approx.10“ from top of intake to top of air filters.
    ~ Spare never needed Weber rebuild kits. Some extra base gaskets. Their tuned specs.
    ~ There are no other parts with this.
    ~ It will be well packed.
    *~ Please note ~*
    ~ I am listing this for another person.
    ~This all the information that he has given me.
    https://www.ebay.com/itm/Weber-44-I…PIAAOSwfWpfBGlp
  • This used Weber setup and intake intake manifold sold June 24, 2020 on Ebay for $2,500.00.
  • This used Weber setup and intake intake manifold is for sale by Ebay seller "breel63" with a starting bid of $1,000.00:
    FORD 289 302 WEBER 48 IDA SMALL BLOCK FORD COBRA MUSTANG SHELBY.18 years old but in good condition, less than 200 miles of street us on a 1965 mustang with a well-built 347. Does not have provisions for vacuum for PCV, brakes, distributor advance, etc... Float valves stuck last time I started the car, causing it to flood. Carb to manifold gaskets will need to be replaced. Includes synchronizer tool (not shown).
    FORD 289 302 WEBER 48 IDA SMALL BLOCK FORD COBRA MUSTANG SHELBY | eBay
    This used Weber setup and intake intake manifold sold March 27, 2023 on Ebay for $2,851.00 with 11 bids from 8 bidders.
  • This used Weber setup and intake intake manifold is for sale by Ebay seller "6172839405" with a Buy-It-Now of $4,950.00 or make offer:
    NOS Weber Style intake (not sure of the maker or era) with original Italian made Weber 48 IDA carburetors. Please see pictures for the numbers and details on the carbs. They seem to be in good condition but might need a light rebuild. The intake is probably a bit newer than the carbs, but it is stunning and NOS.
    Most of the money here is in the carbs!
    Find me by searching "Larson MasterWorks".
    /////701///
    //240////
    /////1641///
    - David
    Ford Small Block Weber Intake NOS w/ Weber 48 IDA Carburetors Original 289 302 | eBay
  • This used Weber setup and intake intake manifold sold February 19, 2025 on Ebay for $3,950.00.
