Display MoreDisplay MoreDisplay MoreHere is anr Ebay auction for a used C5DA bellhousing by Ebay member "bmp6570" with a Buy-It-Now of $375.00:
Original aluminum manual Ford 8-cylinder 289 bellhousing. C5DA 6394 A. Will fit any 289 when using 13 1/4" diameter and 157 tooth flywheels. Has a small crack at one of the holes that is not used anyway as shown in last picture. Threads are good. Has been media blasted.
1965 1966 1967 1968 ORIGINAL MUSTANG FALCON MANUAL BELLHOUSING 289 HIPO 4 SPEED | eBay
This bellhousing has been drilled out to accept the early narrow pattern transmissions. It can be use for that but the casting has no reinforcement to back up the narrow pattern. That is why it is cracked where it is, The seller is correct that this is not an issue, however this only applies if you are using the later wide bolt pattern transmissions.
The listing for this used C5DA bellhousing was ended by the seller October 13, 2022 with the following explanation "This listing was ended by the seller because the item is no longer available".
This used C5DA bellhousing that was "no longer available" is back on Ebay again with no changes to the Buy-It-Now of $375.00:
The listing for this used C5DA bellhousing was ended by the seller November 10, 2022 with the following explanation "This listing was ended by the seller because the item is no longer available".
