Used C5DA Bellhousing
    • Official Post
    Here is an Ebay auction for a used C5DA bellhousing by Ebay member "jarsncars" with a Buy-It-Now of $399.00:
    This is a used original aluminum bell housing. For Borg Warner 4 speed manual transmission. Or Toploader 3 or 4 speed manual transmission. Part number C5DA-6394-A For 1965, 1966, 1967 Ford Mustang, Shelby GT350, Fairlane, Falcon, Comet, Ranchero. Also for 1967, 1968 Cougar. This one has 66 with 3 dots indicating a March of 1966 production. This is a six bolt bellhousing. This bellhousing takes a 157 tooth flywheel and 10 or 10 1/2" clutch. I bought it used, stored it for years and I never installed it. I did not bead blast or paint this bellhousing. Clutch fork, rubber seal and mounting bolts included. Really nice shape. Do your homework. Know your part. Ask questions. Buyer pays $55.00 shipping and handling 48 United States only.
    https://www.ebay.com/itm/PRICE…3b708d:g:-SAAAOSw7iZd6nCt
    • Official Post
    I will say that this one is very nice compared to others out there as this has no broken tabs or locating holes.
    • Official Post
    Here is an Ebay auction for a used C5DA bellhousing by Ebay member "289special" with a Buy-It-Now of $370.00 or make offer:
    This is a used original aluminum bell housing. For Borg Warner 4 speed manual transmission. Or Toploader 3 or 4 speed manual transmission. Part number C5DA-6394-A For 1965, 1966, 1967 Ford Mustang, Shelby GT350, Fairlane, Falcon, Comet, Ranchero. Also for 1967, 1968 Cougar. Also 1965 Cyclone. This is a six bolt bellhousing. This bellhousing takes a 157 teeth flywheel and 10 or 10 1/2" clutch. I bought it used, stored it for years and I never installed it. I did not bead blast or paint this bellhousing. All threads and holes are in excellent condition. Do your homework. Know your part. Ask questions before buying. Buyer pays $30.00 shipping and handling 48 United States only. I will pay the additional shipping over the $30 shipping charge. NOTE: No work was needed or done on this bellhousing. Still has the original factory finish.
    https://www.ebay.com/itm/1965-…id=p2047675.c100005.m1851
    • Official Post
    • Official Post
    This used C5DA bellhousing sold March 24, 2020 on Ebay for $370.00.
    • Official Post
    This used C5DA bellhousing sold May 7, 2020 on Ebay for $349.00.
    • Official Post
    Here is an Ebay auction for a used C5DA bellhousing by Ebay member "bmp6570" with a Buy-It-Now of $285.00:
    This is an original aluminum ford bellhousing that fits 1965-68 mustangs (including HIPO) and Falcons with 289 or 302 6 bolt engines and manual transmission. For 13 1/4" diameter 157 teeth flywheel. Fits 3 or 4 speed. Media blasted. Has one of the dowel pin holes broken as shown in picture #2. Will not cause any problems. Casting #C5DA.
    1965 1966 1967 1968 OEM MUSTANG FALCON 289 302 BELLHOUSING 4 SPEED HIPO C5DA | eBay
    • Official Post
    The listing for this used C5DA bellhousing was ended by the seller December 31, 2020 with the following explanation "This listing was ended by the seller because the item is no longer available".
    -Fred
    • Official Post
    Here is an Ebay auction for a used C5DA bellhousing by Ebay member "bambie930 " with a Buy-It-Now of $395.00:
    Original Shelby or Mustang 289 HIPO "K" Code 4 Speed 6 Bolt Bellhousing. There are no cracks or repairs or stripped threads. This even comes with the original 6 Bolt Separator Plate.
    1965-1967 SHELBY MUSTANG 289 HIPO "K" 6 BOLT BELL HOUSING C5DA-6394-A ORIGINAL | eBay
    • Official Post
    Here is an Ebay auction for a used C5DA bellhousing by Ebay member "susanandsuzyco " with a Buy-It-Now of $300.00:
    This is a factory original
    1965-67 Ford Mustang Shelby HiPo 289
    'K' Code Aluminum Bell Housing with Clutch Fork and
    Mounting Bolts
    The bellhousing is in excellent restored condition. It, along with the
    clutch fork and mounting bolts, were glass beaded and painted with a super
    strong, 500+ high temperature, high performance, ceramic engine paint.
    The correct and matching clutch fork did have some pitting on the one
    end but is still in good useable condition. The bellhousing mounting bolts
    and the transmission mount bolts are also included.
    Everything is ready for installation
    This is correct for a 6 bolt block pattern and a 157 tooth flywheel.
    Ford #C5DA-6394-A
    Clutch Fork #C8OA-7515-A
    1965 66 67 FORD MUSTANG SHELBY 289 HI PO BELLHOUSING K Code C5DA w/ Fork & Bolts | eBay
    • Official Post
    This used C5DA bellhousing sold January 24, 2021 on Ebay for $300.00.
    • Official Post
    This used C5DA bellhousing that was "no longer available" is back on Ebay again with no changes:
    • Official Post
    The listing for this used C5DA bellhousing was ended by the seller January 29, 2021 with the following explanation "This listing was ended by the seller because the item is no longer available".
    -Fred
    • Official Post
    Here is an Ebay auction for a used C5DA bellhousing by Ebay member "jauntiek351 " with a Buy-It-Now of $344.44:
    This auction is for a clean used Original Manual Transmission Bell Housing for a 1965 1966 1967 1968 Ford Mustang Shelby GT350 Cougar Fairlane Torino Cyclone Comet Montego and Ranchero. This fits 289 289 HiPo Special 302 V8's with 3 and 4 speed manual transmissions. It accepts the 157 tooth flywheel and will work in 1969 and later 302 if you change the clutch fork pivot or use the early clutch fork. It carries Ford ID number C5DA-6394-A. One of the alignment holes has a chip out of it ( see pictures ) which will not affect the performance of this unit. It is clean and ready to install. We accept Paypal , Visa, Mastercard, Discover and American Express. If you have any questions or need other clutch linkage or 4 speed components please ask. Thank-you and Happy Ebaying! (120420)
    1965 1966 1967 1968 FORD MUSTANG 289 302 3 4 SPEED BELL HOUSING C5DA 157tooth | eBay
    • Official Post
    This used C5DA bellhousing sold January 30, 2021 on Ebay for $327.22.
    • Official Post
    This used C5DA bellhousing and separator plate sold February 15, 2021 on Ebay for $395.00.
    • Official Post
    • Official Post
    Here is an Ebay auction for a used C5DA bellhousing by Ebay member "jauntiek351 " with a Buy-It-Now of $358.88:
    This auction is for a clean used Original Manual Transmission Bell Housing for a 1965 1966 1967 1968 Ford Mustang Shelby GT350 Cougar Fairlane Torino Cyclone Comet Montego and Ranchero. This fits 289 289 HiPo Special 302 V8's with 3 and 4 speed manual transmissions. It includes the clutch fork pivot and accepts a 157 tooth flywheel. It will also work on 1969 and newer 302 if you change the clutch fork pivot or use the early clutch fork. It carries Ford ID number C5DA-6394-A and is clean and ready to install. We accept Paypal , Visa, Mastercard, Discover and American Express. If you have any questions or need other clutch linkage or 4 speed components please ask. Thank-you and Happy Ebaying! (031021)
    • Official Post
    The listing for this used C5DA bellhousing was ended by the seller March 19, 2021 with the following explanation "This listing was ended by the seller because the item is no longer available".
    -Fred
    • Official Post
    This used C5DA bellhousing sold March 19, 2021 on Ebay for $358.88.
