65 K code fastback project for sale
  • '65 'K' code Fastback for sale. Original CA car with 2 black plates. Needs someone from CA to care for it and bring it back to life. Here is a list of non-original parts: 4-speed trans, 8" rearend, block, heads, exhaust. Everything else is original, including factory disc brakes, 4 bbl Autolite, dual pt dist and 4 blade fan as well as many new parts to get you going.
    VIN 5R09K153391, Body 63A, Color 3, Trim 26, Date 31K, DSO 71, Axle/Trans 5 5, miles 39398.
    Make an offer!!! I will be able to tell by your offer if you want the car yourself to restore or if you are looking to make a quick buck by re-selling. Serious inquires only.
    ccmyers8@suddenlink.net
  • I will try to get some pics up asap. It doesn't have the hipo block or heads or exhaust or rear end. I know its a sad thing when the original owner races it and blows the engine and replaces it with just a 289 engine. The rare piece of this car, as you all know, is the 'K' fender well stamp. We all can find the pieces to make it a hipo again, but you won't find a fastback body in this good of shape. Along with the body, it has the factory original carb, distributor, intake, four blade fan and dics brakes. The ONLY rust you will find is around the bottom of the window, which is surface only. 15K takes it.
  • clearly, we on the Ex change would ALL like to see what EXACTLY you have, so ask for help, and we will get it all up here for all to d to see!!see.Exciterd:D:D
  • Kar is sold
