• Quote from Abandoned_classics
    Just bought this very complete K engine from an old garage. Will be going into my Fastback if no one comes forward!
    Is there a vin on the block, any details on condition 5 or 6 bolt, date codes ,location,do you have a price for it.
  • Quote from chucks302
    Chuck, The way that I read the OP message here is that he only has the engine. In that case the VIN posted must have come from the engine. If it is the approximate production date of the Kar was late September 1964 and would be a 6 bolt block. I certainly could be wrong on where the VIN came from but these are my thoughts.
  • Chuck, The way that I read the OP message here is that he only has the engine. In that case the VIN posted must have come from the engine. If it is the approximate production date of the Kar was late September 1964 and would be a 6 bolt block. I certainly could be wrong on where the VIN came from but these are my thoughts.
    You are correct. I have a K code fastback with a 351 Windsor in it right now. I just bought a bunch of parts from a garage south of Tucson, including that K engine. The engine is mostly complete and is vin stamped with 5R07K142861. I have not checked all of the date codes and am not sure if it’s 5 or 6 bolt block. I will check when I get home!
  • Quote from C6ZZKGT
    Abandoned_classics
    If you post the VIN for your fastback, it is possible that you may locate your original engine or pieces.
  • You are correct. I have a K code fastback with a 351 Windsor in it right now. I just bought a bunch of parts from a garage south of Tucson, including that K engine. The engine is mostly complete and is vin stamped with 5R07K142861. I have not checked all of the date codes and am not sure if it’s 5 or 6 bolt block. I will check when I get home!
    Abandoned_classics
    5R09K241895 I believe it’s in a registry already. I found it in a yard in Pinetop, Arizona. no motor or trans.
    Abandoned_classics
    I just checked all of my blocks and I am sorry but I do not have yours.
  • 5R09K241895 I believe it’s in a registry already. I found it in a yard in Pinetop, Arizona. no motor or trans.
    Not surprising, but thanks for checking!
    i started to disassemble 5R07K142861
    -6 bolt C5AE-6015E 4H11 with VIN
    -19 head 4J16 , 21 head 4J16
    -C4OFAL manual choke with 11•5•63 stamped underneath
    -C5OF 12127 E 4JB FOMOCO distributor
    -Complete motor mounts
    -Correct valve covers
    -Intake C5AE-9425-M 4K21
  • That is quite a gem that you have there. What about the fuel pump, water pump and timing cover?
    Water pump, fuel pump, air cleaner and fan are MIA. Timing cover is correct. I got two sets of correct exhaust manifolds with the deal as well as a CJ flex plate. the fuel pump and fan may be in the garage somewhere, the gentleman that passed away had a lot of high dollar cars and parts in this garage. He disassembled almost everything and never put it back together. The distributor in the engine now is not the correct one. But the right one was laying close by. Good thing I looked, not bad for $4500 I don’t think.
    Yes, I would say that you made an excellent deal on that engine.
