Used C4AE Timing Cover
  • Here is an Ebay auction for a used C4AE timing cover by Ebay member "oldcrabs" with a Buy-It-Now of $99.00:
    C4AE-6509-B cover with February of 1964 date code. Threads all look good.
    No corrosion around water holes. Has some cavitation pitting in the impeller area and some pry marks.
    This is the version where the breathe tube hole is cast shut.
    Has the two small ribs on the backside above the water pump area.
    New lower price!
    https://www.ebay.com/itm/1964-FORD-…=p2047675.l2557
    Edited once, last by C6ZZKGT (October 9, 2019 at 3:44 PM).
  • This used C4AE timing cover was ended by the seller September 29, 2019 with the following explanation "This listing was ended by the seller because there was an error in the listing".
    Edited once, last by C6ZZKGT (October 9, 2019 at 3:43 PM).
  • Quote from C6ZZKGT
    This used C4AE timing cover is back on Ebay again with no changes:
    https://www.ebay.com/itm/2740435460…=STRK:MEWAX:VRI
