Used C4ZR Toploader Tail Housing
  • Here is an Ebay auction for a used C4ZR toploader tail housing by Ebay member "papajoe5557" with a Buy-It-Now of $299.99 or make offer:
    1965 - 1967 MUSTANG TOPLOADER C4ZR 7A040 A TAILHOUSING. VERY NICE RUST AND PIT FREE SOUTHERN CALIFORNIA PART. GETTING VERY HARD TO FIND IN ANY CONDTION LET ALONE THIS NICE. WILL FIT OTHER YEAR MUSTANGS AS WELL USING CORRECT TRANSMISSION MOUNT
    https://www.ebay.com/itm/1965-…f63536:g:rdkAAOSwsIBdXfWM
    Edited once, last by C6ZZKGT (October 9, 2019 at 4:27 PM).
  • Quote from C6ZZKGT
    https://www.ebay.com/itm/1965-1967-…dkAAOSwsIBdXfWM
    This used C4ZR toploader tail housing sold November 9, 2019 on Ebay for $299.99.
  • Here is an Ebay auction for a used C4ZR toploader tail housing by Ebay member "agwinged " with a Buy-It-Now of $195.00 or make offer:
    65 to 71 Mustang & Cougar C4ZR-7A040-A tail shaft for a Top Loader transmission that originally came on 289, 302, and 351 engines with 4 or 3 speed combination. Date code: F22 W 2
    The tail shaft is 14 inches long and will accept a 25 or 28 spline transmission shaft. It has been media blasted and washed clean to ensure zero rust, old paint, or cracks and then painted with cast spray. Comes with a new rear tailshaft seal from National Seals.
    https://www.ebay.com/itm/C4ZR-7A040…cgAAOSwCmBeJ3Go
  • This used C4ZR toploader tail housing sold January 27, 2010 on Ebay for $195.00.
  • Here is an Ebay auction for a used C4ZR toploader tail housing by Ebay member "pashli0" with a starting bid of $250.00:
    Nice original Ford USED part. Part number C4ZR (see photos). Correct for use with 66-66 Ford Mustang manual 4-speed toploader applications (HEH). no repairs, no issues, still retains original output shaft sleeve bearing and seal (easily removed and replaced). correct for original (stock) 4-speed shifter setup (note speedometer cable mount is on passenger side, correct for GT/Hipo)
    65 66 1965 1966 Mustang Ford 4 Speed Toploader Tail Shaft USED | eBay
    This used C4ZR toploader tail housing sold June 26, 2012 on Ebay for $250.00.
