used C3OZ 8592 A Thermostat Housing
  • Here is an Ebay auction for a used C3OZ 8592 A thermostat housing by Ebay member "valhallastudio" with a Buy-It-Now of $179.99:
    Thermostat housing, no oxidation, correct mounting hardware, see pictures for condition.
    See my other Ford parts listed.
    https://www.ebay.com/itm/1964-1-2-1…5kAAOSwOI1dhvtH
    Edited once, last by C6ZZKGT (November 3, 2019 at 3:28 PM).
  • Quote from C6ZZKGT
    The price is now $89.99.
  • Here is an Ebay auction for a used C3OZ 8592 A thermostat housing by Ebay member "magmustangs" with a Buy-It-Now of $89.00:
    1964-1965 Ford Mustang, Fastback, Coupe, Convertible, GT, Shelby GT-350, Falcon, Sprint, Fairlane, Ranchero, Mercury Cougar, XR7, Comet, S-22, Caliente, Cyclone. . . .... 260 / 289 2V-4V-HIPO Thermostat Housing-Water Neck. 'ALUMINUM'. This is an ORIGINAL FORD PART. Casting Number (FoMoCo) C4OE-8594-A. Dated (12...63).. The Housing is in Good Original Condition.. NO Cracks or Damage. There is some Pitting on the Metal, This Will Still Mount and Seal Well. . Good Mounting Surface. No Heavy Corrosion . . Overall, this is a Good Original 260-289 Thermostat Housing.. Impossible To Find Original. ..
    https://www.ebay.com/itm/1964-1965-…0EAAOSw5FJa4PBx
    1963 Shelby Cobra, Ford Falcon Sprint, Fairlane, 500, Mercury Comet S-22... 260 / 289 HIPO Thermostat Housing-Water Neck. 'ALUMINUM'. Might possibly be correct for Early 1964 model year also, I'm not sure.. This is an ORIGINAL FORD PART. Casting Number (FoMoCo) C3OE-8594-A. Dated (6...63).. The Housing is in Great Original Condition.. NO Cracks or Damage. There is some Pitting on the Metal, This Will Still Mount and Seal Well. . Good Mounting Surface. No major Corrosion . . Overall, this is a Great Original 260-289 Thermostat Housing.. Impossible To Find Original. ..
    https://www.ebay.com/itm/1963-Ford-…RoAAOSw8Z9a3652
  • This used C3OZ 8592 A thermostat housing sold March 13, 2020 on Ebay for $75.00.
  • Here is an Ebay auction for a used C3OZ 8592 A thermostat housing by Ebay member "tolisto_0" with a Buy-It-Now of $46.00 or make offer:
    1961-73 Ford 260 289 302 351W Aluminum Water Neck Thermostat Housing 5/8 bypass C3OE-8594 USED
    Cast aluminum thermostat housing water neck outlet connection USED fits SBF small-block Ford engines: 260 F code, 289 (A, C, D), 302 & 351W engines / motors.
    Hard-to-find, exact reproduction, original Ford FoMoCo part w/ correct C3OE-8594 casting number & the letters "SD" stamped on it.
    I removed it from my S-Calif, 1963 Ford Fairlane 500 Sports Coupe 2-Door Hardtop w/ 70s 302 engine that had about 800-1,000 miles on it.
    I changed the entire cooling system so no longer need this part.
    It is a high-quality, pressure-tested & stress-relieved, premium-quality reproduction part.
    It also has the 5/8” bypass outlet on the side, to accept original bypass hose. Thermostat flange opening is 2-1/8” OD outside diameter & 1-13/16” ID inside diameter.
    Overall, great original condition: no major corrosion, cracks or oxidation damage.
    There is some light pitting (that will be concealed once installed) but mounting surface is good & rests flat so it will still mount & seal well.
    Designed for the customer who wants durability closer to stainless steel, but the weight of aluminum. Replace that too-smooth or chromed repro water neck w/ a production OEM part that looks & fits right - front & center.
    It is not unique to the HIPO / HP engine(s) & is NOT for big blocks, thermactor missions or thermal switches. Some 1968 & up parts are different w/ pipe thread boss on top - this is the thermo housing without that top tapped hole.
    https://www.ebay.com/itm/1961-73-Fo…80AAOSw0V1ewwN-
  • The seller is in error on the fitment of this housing as it ONLY fits up to a partial model year of 1965. The issue is the lack of a recess for the thermostat. Early cars have the recess in the intake manifold. The later cars do not and if you try to install a thermostat with this housing on a later car, you will break the housing when tightening up the bolts.
  • The listing for this used C3OZ 8592 A thermostat housing was ended by the seller June 1, 2020 with the following explanation "This listing was ended by the seller because the item is no longer available".
  • This used C3OZ 8592 A thermostat housing that was "no longer available" is back on Ebay again with a new lower Buy-It-Now of $40.00 or make offer:
    https://www.ebay.com/itm/2839177301…=STRK:MEWAX:VRI
  • This used C3OZ 8592 A thermostat housing sold June 20, 2020 on Ebay for $40.00.
  • Here is an Ebay auction for another used C3OZ 8592 A thermostat housing by Ebay member "magmustangs" with a starting bid of $89.00:
    1963 Shelby Cobra, Ford Falcon Sprint, Fairlane, 500, Mercury Comet S-22. 260 / 289 HIPO Thermostat Housing-Water Neck. 'ALUMINUM'. Might possibly be correct for Early 1964 model year also, I'm not sure.. This is an ORIGINAL FORD PART. Casting Number (FoMoCo) C3OE-8594-A. Looks to be Dated (6...63).. The Housing is in Great Original Condition.. NO Cracks or Damage. There is some Pitting on the Snout but This Will Still Mount and Seal Well. Great Mounting Surface. No major Corrosion. Overall, this is a Great Original 260-289 Thermostat Housing. Impossible To Find Original
    1963 64 Ford Falcon Fairlane Shelby Cobra ORIG 260 289 Hipo THERMOSTAT HOUSING | eBay
    This used C3OZ 8592 A thermostat housing received no bids by December 25, 2020 and therefore did NOT sell.
  • This used C3OZ 8592 A thermostat housing is back on Ebay again with no changes:
  • This used C3OZ 8592 A thermostat housing received no bids by January 1, 2021 and therefore did NOT sell.
  • Here is an Ebay auction for a used C3OZ 8592 A thermostat housing by Ebay member "munson6566" with a Buy-It-Now of $49.95:
    YOU ARE VIEWING A ORIGINAL FORD 221 , 260 OR 289 THERMOSTAT HOUSING .
    THE FORD PART NUMBER IS : C3OZ 8594 A
    THE ID NUMBER IS : C3OE 8594 A
    THIS IS A ORIGINAL FORD 221 , 260 OR 289 THERMOSTAT HOUSING .
    THIS HOUSING IS THE EARLY STYLE WITHOUT THE RECESSED POCKET FOR THE THERMOSTAT .
    THE HOUSING IS NICE , NO CRACKS OR REPAIRS .
    THIS AUCTION IS FOR 1 PIECE .
    LOCATION BOX 23
    THIS FITS :
    1962 1963 1964 1965 FORD GALAXIE FAIRLANE FALCON MERCURY COMET METEOR 221 260 289 289HP BEFORE 3-1-1965
    1964 1/2 1965 FORD MUSTANG 260 2892V 4V OR 289H/P BEFORE 3-1-65
    ORIGINAL 1963 1964 1965 FORD 289 2V 4V H/P THERMOSTAT HOUSING C3OZ 8594 A | eBay
  • Here is an Ebay auction for another used C3OZ 8592 A thermostat housing by Ebay member "magmustangs" with a Buy-It-Now of $89.00:
    1963 Shelby Cobra, Ford Falcon Sprint, Fairlane, 500, Mercury Comet S-22... 260 / 289 HIPO Thermostat Housing-Water Neck. 'ALUMINUM'. Might possibly be correct for Early 1964 model year also, I'm not sure.. This is an ORIGINAL FORD PART. Casting Number (FoMoCo) C3OE-8594-A. Looks to be Dated (6...63).. The Housing is in Great Original Condition.. NO Cracks or Damage. There is some Pitting on the Metal, This Will Still Mount and Seal Well. . Good Mounting Surface. No major Corrosion . . Overall, this is a Great Original 260-289 Thermostat Housing.. Impossible To Find Original. .. Please email with questions. 051718-11 CHECK OUT OUR EBAY STORE WITH THOUSANDS OF ORIGINAL FORD PARTS.
    1963 Ford Falcon Fairlane Comet Shelby Cobra ORG 260 289 Hipo THERMOSTAT HOUSING | eBay
  • This used C3OZ 8592 A thermostat housing received no bids by January 8, 2021 and therefore did NOT sell.
  • This used C3OZ 8592 A thermostat housing received no bids by January 15, 2021 and therefore did NOT sell.
    -Fred
