- Official Post
Here is an Ebay auction for a rebuilt Hipo 289 engine by Ebay member "tony-bogo" with a Buy-It-Now of $14,995.00 or make offer:
Offered for sale is a TNT Engineering custom built 289 Hipo GT350 Shelby engine. The engine is built using original 289 Hipo date matched heads and block. We have several date codes available including early 5 bolt blocks. Please contact us for our current inventory. Every engine is blueprinted and test run before delivery. The timing is set and the carburetor is jetted for an easy installation. The engine is delivered air cleaner to oil pan and balancer to flywheel.
Note: The engines pictured were previously built for customers and may have items and options shown that are not included
Here is a complete list of what is included with the engine:
-Original 289 Hipo Block with Correct Main Caps Baked, Blasted, Magged, Bored and Honed with a Torque Plate to 4.030" typically, Align Honed and Decked
-Original 289 Crankshaft Ground .010” and .010” Externally Balanced, 3/8” Bolt Rods Cleaned, Magged and Resized with ARP Bolts, Hipo Replacement Pistons 10.5 to 1, Total Seal Rings, King Bearings, New Hipo Balancer
Melling HV Oil Pump, ARP Drive, New Cobra Oil Pan
-Original 289 Hipo Heads with Replacement Valves, Crower Valve Springs and Hardware
-New Cobra Intake, New 3259 Lemans Bowl Carburetor, New Fuel Pump and Correct Fuel Line
-New Timing Set with Original Balance Hatchet, 289 Hipo Replacement Camshaft, New Solid Lifters, New Pushrods, Correct Rocker Arms
-289 Dual Point Distributor, Autolite Distributor Cap, Reproduction 289 Hipo Wires, Mustard Top Coil, Autolite Spark Plugs
-New Cobra Valve Covers, Original Timing Cover, New Water Pump and AMK Hardware Kit
We reserve the right to change or upgrade parts depending on availability.
Here is a list of some common options:
Electronic Ignition
Forged Pistons
Stainless Valves
Custom Polishing
Let me know if you are interested in options not listed.
We accept payment by Wire, Check, Credit Card and Cash in Person. If you have any questions you can contact Tony at [phone removed by eBay] or Tonys427 Yahoo
TNTENGINEERING.US
https://www.ebay.com/itm/289-HIPO-G…e8AAOSwYPNcWyQl
