• Here is an Ebay auction for a pair of used C8ZE heads by Ebay member "fordluvr2" with a Buy-It-Now of $2,000.00 or make offer:
    This is a pair of used 289 HI-PO heads. These were also the heads sent to Crane Cams to make the famous "CRANE FIREBALL" heads. This set in particular, never had the emission holes taped into the exhaust ports. Which gives these heads all sorts of possibilities as far as porting goes. This pair has all the standard HI-PO factory upgrades as well. Factory screw in studs. Cast valve spring cups. 20 and 21 on the corners of the heads. These heads are service replacements with casting C8ZE-B, dated 8-F-20. Very nice heads, look like they may have been milled on the block side at some point. Missing one rocker and stud. Will need to be rebuilt to use.
    https://www.ebay.com/itm/FORD-289-H…2AAAOSwBz1cqgTb
    Edited once, last by C6ZZKGT (July 18, 2019 at 5:05 PM).
  • Quote from C6ZZKGT
    This pair of used C8ZE heads sold July 18, 2019 on Ebay for $2,000.00.
    • Official Post
    Here is an Ebay auction for a pair of used C8ZE heads by Ebay member "motoman6767" with a Buy-It-Now of $1,200.00:
    Ford 289 hipo K Code Cylinder Heads, Crane fireball! C8ZE-B. Condition is Used. Very rare set of Hipo heads ported by Crane in the 60s! Matching cast date of 9K23. Valve size is 1.94 IN/ 1.625 EX. They show some use and came from a 302 Mexican block engine I purchased many years ago and we're shelved! I believe it was built for drag racing and have never used these heads! I've been told they will breath over 400 HP? Please ask and I will answer any questions!
    https://www.ebay.com/itm/Ford-289-h…cwAAOSw4MBesHSY
    • Official Post
    This pair of used C8ZE heads sold May 6, 2020 on Ebay for $1,200.00.
  • Here is an Ebay auction for a pair of used C8ZE heads by Ebay member "valhallastudio" with a Buy-It-Now of $989.95:
    Complete matching pair of heads, small chamber and big valves, good threads and no sunk valves or porting, see pictures for condition.
    See my other Ford parts listed.
    https://www.ebay.com/itm/1963-1964-…nYAAOSwKp9fPxUd
    This pair of used C8ZE heads sold August 21, 2020 on Ebay for $989.95.
  • Here is an Ebay auction for a pair of used C8ZE heads by Ebay member "boylercr13 " with a starting bid of $200.00 and a Buy-It-Now of $1,200.00:
    Matched pair of Original 289 Hi Po Cylinder Heads, casting# C8ZE-B. They came off of an 5.0 engine that I purchased, so I don't have detailed information about work that has been done to them. They do have screw-in studs and aftermarket dual valve springs and retainers. The info I have researched says that they are Ford factory service Hi-Po replacement heads. The casting numbers and dates on both heads match. Local Pick-up preferred, but will ship at your expense.
    https://www.ebay.com/itm/Ford-289-H…sgAAOSw2NVfgLnF
    This pair of used C8ZE heads was bid to $365.00 by October19, 2020 with 5 bids from 4 bidders but did not meet the sellers reserve and therefore did NOT sell.
    This pair of used C8ZE heads are back on Ebay again with a Buy-It-Now of $700.00 or make offer:
  • This pair of used C8ZE heads sold November 12, 2020 on Ebay for $700.00.
  • Here is an Ebay auction for a pair of used C8ZE heads by Ebay member "shelbyoner" with a starting bid of $1,200.00:
    Ford 289 Hi Po Cylinder Heads. Condition is "Used".
    Ford 289 Hi Po Cylinder Heads | eBay
  • Here is an Ebay auction for a single used C8ZE head by Ebay member "sirelliott" with a starting bid of $500.00:
    You are bidding on a nice SINGLE OEM Ford Mustang Shelby Fairlane 289 HiPo 67-68 cylinder head. Date code 3F4. Very good condition. Has a small crack on one of the rocker arm bosses, see pics. Looks like very mild porting or bowl blending has also been done, but they did very good job. May fit other vehicles. Check your application. Will make a nice addition to your OEM restoration or daily driver.
    Thanks for looking and good luck bidding. I offer local pick up. Will ship worldwide but shipping will be more. Flat rate shipping if offered, is for lower 48 ONLY. Check out my other auctions. Also have other FE & Cleveland heads, Intakes, blocks, cranks etc. If you need additional info, please e-mail me at bmoye2000 at bellsouth dot net or call 7705843022.
    67-68 FORD SHELBY MUSTANG 289 HIPO OEM SINGLE CYLINDER HEAD K CODE GT350 | eBay
    This head has a fairly common issue and is noted by the seller of the small crack in the rocker stud boss. There are actually 3 of the cracks and I recommend a repair be done before using the head. It is not an easy repair as brazing will not work so it needs to be cast iron welded. I have had a few of these heads with this issue successfully repaired but it is not cheap. These cracks are generally caused by use of a non Ford rocker stud which has the wrong radius where the threads end at the base of the stud.
  • This single used C8ZE head received no bids by February 5, 2021 and therefore did NOT sell.
    This pair of used C8ZE heads received no bids by February 5, 2021 and therefore did NOT sell.
  • This pair of used C8ZE heads is back on Ebay again with no changes:
  • This single used C8ZE head is back on Ebay again with a Buy-It-Now of $595.00 or make offer:
  • This pair of used C8ZE heads received no bids by February 12, 2021 and therefore did NOT sell.
  • This pair of used C8ZE heads received no bids by February 19, 2021 and therefore did NOT sell.
