Dual Point Distributer Points and Condenser
  • Hey all,
    So can you use DP-6 points or do you have to use DP-5 in our dual point distributers? Specifically talking about 65/66 distributers. Also what condenser part number should it be as well, DC-13?
    Jason
    Edited once, last by Morsel (May 1, 2019 at 12:50 AM).
    • Official Post
    Hey all,
    Jason
    Jason,
    DP-6 is the actual correct number for the points. The DC-13 condenser is for single points and has the mounting tab towards the end of the condenser. A DC-6 is the proper condenser as it is setup for a side mount tab on the condenser. Some come with the side mount strap loose in the box.
    Yes, I do have these in stock.
  • [quote pid='538' dateline='1556714956']
    Jason,
    [/quote]
    Thanks for the info Fred, I was making sure because I have an Autolite TKF-14 tuneup kit and before I crack it wanted to make sure it's contents are correct for what I need out of it, plus I really want to see if it has original Autolite Star BF-32 plugs in it ;)
    But really didn't want to pop the seal if it's not what I need.
    Jason
    • Official Post
    Jason,
    Jason
    [/quote]
    The Autolite Star plugs had long since gone away before Ford came out with the tune up kits in the cans. Bummer!!!
  • Thanks for the info Fred, I was making sure because I have an Autolite TKF-14 tuneup kit and before I crack it wanted to make sure it's contents are correct for what I need out of it, plus I really want to see if it has original Autolite Star BF-32 plugs in it ;)
    Jason
    [/quote]
    Really, I thought the early Tune Up kits had the star plugs, if not, not going to pop it then, haha...
    Jason
