Used C3OE Harmonic Balancer
  • Here is an Ebay auction for a used C3OE Hipo harmonic balancer by Ebay member "bluerockieroad" with a Buy-It-Now of $550.00 or make offer:
    289 Original HIPO BALANCER C30E. Condition is Used. Date code H3 August 1963
    https://www.ebay.com/itm/289-Origin…275.c4#viTabs_0
    Edited once, last by C6ZZKGT (April 24, 2019 at 2:49 PM).
  • Here is an Ebay auction for a used C3OE Hipo harmonic balancer by Ebay member "acman63" with a Buy-It-Now of $550.00:
    289 Hipo Harmonic Balancer original. This is an original C3OE damper stamped date 3L Nice original that has been to the the harmonic balancer guru for a checkup to make sure the seal is new and hasn’t spun. Shaft has a new redo sleeve. ready to install on that early hipo 289 engine.
    https://www.ebay.com/itm/289-Hipo-H…5.c100010.m2109
  • Here is an Ebay auction for a used C3OE Hipo harmonic balancer by Ebay member "cincop8" with a Buy-It-Now of $695.00 or make offer:
    Fits 1964 1965 1966 1967 K code 289. Hipo harmonic balancer. C3OE original ford hipo 289. Early production probably from a 1964 Ford hipo Fairlane , Sunbeam Tiger ,Shelby, Cobra or 1964.5 mustang. Good original condition. Rare item.
    https://www.ebay.com/itm/K-code-196…FcAAOSwEEVdTHdP
  • Quote from C6ZZKGT
    This balancer has an L3 date code.
    Buy-It-Now is now lowered to $525.00.
  • Here is an Ebay auction for a used C3OE Hipo harmonic balancer by Ebay member "4speed421" with a starting bid of $550.00:
    This is a rare original balancer for the early High Performance Ford 289 used in the 1964 AC Cobra or the Fairlane. Date code L3 , cast # C3OE-B. Not flawless but very nice, Very very light pits in a spot or two. Primer will fill what few are here. A few very light ding marks, some of which are behind the pulley when installed. Glass beaded 100% clean. You can see everything! No paint to try and hide flaws. Seal surface not perfect but very usable as is with no fear of leaks. [/size][size=4]NO cracks in key way like many have. The 3 bolt hole threads are perfect and have NO repairs. Rubber ring pretty good and better than most. Looks like it has never been balanced other than from the Ford factory. This is a nice virgin balancer.
    I would rate this balancer in "B" condition..
    https://www.ebay.com/itm/Hipo-289-B…m4383.l4275.c10
    [size=4]This is a rare original balancer for the early High Performance Ford 289 used in the 1964 AC Cobra or the Fairlane. Date code L3 , cast # C3OE-B. Not flawless but very nice, Very very light pits in a spot or two. Primer will fill what few are here. A few very light ding marks, some of which are behind the pulley when installed. Glass beaded 100% clean. You can see everything! No paint to try and hide flaws. Seal surface not perfect but very usable as is with no fear of leaks. [/size][size=4]NO cracks in key way like many have. The 3 bolt hole threads are perfect and have NO repairs. Rubber ring pretty good and better than most. Looks like it has never been balanced other than from the Ford factory. [/size][size=4]This is a nice virgin balancer. [/size]
    [size=4] I would rate this balancer in "B" condition.[/size]
    This used C3OE harmonic balancer received no bids by December 18, 2019 and therefore did NOT sell.
    This used C3OE harmonic balancer is back on Ebay again with no changes:
    https://www.ebay.com/itm/2837197562…em=283719756289
    This used C3OE Hipo harmonic balancer sold December 31, 2019 on Ebay for $475.00.
  • Here is an Ebay auction for a used C3OE Hipo harmonic balancer by Ebay member "papajoe5557" with a Buy-It-Now of $399.99 or make offer:
    VINTAGE ORIGINAL C30E 289 HIPO K CODE AC COBRA HARMONIC BALANCER. SOME HAMMER MARKS BUT WILL WORK FINE. VERY RARE HARD TO FIND PART
    https://www.ebay.com/itm/1240484328…mMakeTrack=true
    This used C3OE Hipo harmonic balancer sold January 18, 2020 on Ebay for $550.00.
    This used C3OE Hipo harmonic balancer sold January 20, 2020 on Ebay for $399.99.
    This used C3OE Hipo harmonic balancer sold April 27, 2020 on Ebay for $550.00.
  • Here is an Ebay auction for a used C3OE Hipo harmonic balancer by Ebay member "papajoe5557" with a Buy-It-Now of $499.99 or make offer:
    VERY HARD TO FIND C30E 1963 1964 EARLY 289 HIPO K CODE AC COBRA BALANCER COMET FAIRLANE SHELBY GT 350 GT40 MK 1. SOME LIGHT HAMMER MARKS BUT VERU NICE 55 YEAR OLD OEM PART
    https://www.ebay.com/itm/C30E-1963-…m4383.l4275.c10
    I believe that this is probably the same balancer that this seller sold earlier this year which is the post just before this one. The description is the same and C3OE balancers are uncommon.
  • Here is an Ebay auction for a used C3OE Hipo harmonic balancer by Ebay member "valhallastudio" with a Buy-It-Now of $478.95:
    289 harmonic balancer, see pictures for condition. H3; August 1963.
    See my other Ford parts listed.
    https://www.ebay.com/itm/289-HIPO-B…rcAAOSwr0RfBQ9i
  • The listing for this used C3OE Hipo harmonic balancer was ended by the seller July 15, 2020 with the following explanation "This listing was ended by the seller because the item is no longer available".
    This used C3OE Hipo harmonic balancer sold November 22, 2020 on Ebay for $430.00.
  • Here is an Ebay auction for a used C3OE Hipo harmonic balancer by Ebay member "jollyroge" with a starting bid of $0.99:
    Original Ford 289 Hi-Po harmonic balancer Shelby GT350 Cobra. Here is an original 289 Hi-Po balancer that is in nice shape. This is the earlier variation with the C3OE Ford part number. This was removed from a 65 Shelby GT350 but would be correct for any 289 Hi-Po engine including Shelby Mustangs. It is in very nice shape with the seal surface showing hardly any wear and nice clear timing marks. It has an A4 date . The rubber is cracked and I would say this needs to go to “The Dampner Doctor “ in Redding California to be rebuilt . No extra holes drilled for non stock balancing . The repro balancers are available but do not carry a Ford logo or part number on them
    Here is your chance to get an original balancer that has not been all beaten up. This balancer would be correct for all 63-67 Shelby GT350’s and any other 289 Hi-Po powered vehicle including 289 Cobras. If you need this for your K code car don’t pass it up! Winner pays actual shipping charges. Good luck bidding !
    Original C3OE Ford 289 Hi-Po K code harmonic balancer Shelby GT350 Mustang Cobra | eBay
    This used C3OE Hipo harmonic balancer sold January 31, 2021 on Ebay for $275.00 with 11 bids from 7 bidders.
