Used C3DZ 8146 D Radiator Fan Shroud
  • Here is an Ebay auction for a used radiator fan shroud by Ebay member "magmustangs" with a Buy-It-Now of $199.00:
    1964.5-1966 Ford Mustang, Fastback, Coupe, Convertible, GT, Shelby GT350. 260-289 RADIATOR FAN SHROUD. For Cars with 260-289 and A/C-Air Conditioning Or 289 HIPO Engine.. This is an ORIGINAL FORD PART. Removed from a 65 Mustang Fastback with 289 Hipo. The Shroud is in Great Original Condition. It is very straight and very round. No cracks or splits. This is still in the factory finish but has surface discoloration all over. No real rust or metal pitting. this is a very solid shroud. Overall, this is a Great Original 260/289 A/C-Hipo Radiator Cooling Fan Shroud. IMPOSSIBLE TO FIND ORIGINAL.
    https://www.ebay.com/itm/1532148000…e=STRK:MEWAX:IT
  • Here is an Ebay auction for another used radiator fan shroud by Ebay member "magmustangs" with a starting bid of $189.00:
    1964.5-1966 Ford Mustang, Fastback, Coupe, Convertible, GT, Shelby GT350. 260-289 RADIATOR FAN SHROUD. For Cars with 260-289 and A/C-Air Conditioning Or 289 HIPO Engine.. This is an ORIGINAL FORD PART. Removed from a 65 Mustang with 289 and A/C. The Shroud is in Good Original Condition. It is straight and round. There are some dings around the inner opening and one side of the mounting flange has a section of curled edge. No cracks or splits. This is still in the factory finish but has surface discoloration all over. No real rust or metal pitting. This is a very solid shroud. Overall, this is a Good Original 260/289 A/C-Hipo Radiator Cooling Fan Shroud. IMPOSSIBLE TO FIND ORIGINAL.
    https://www.ebay.com/itm/1964-1-2-1…&orig_cvip=true
    Edited once, last by C6ZZKGT (March 31, 2019 at 4:14 PM).
    This used fan shroud received no bids by March 23, 2019 and therefore did NOT sell.
    Edited once, last by C6ZZKGT (March 31, 2019 at 4:15 PM).
  • This used fan shroud received no bids by March 23, 2019 and therefore did NOT sell.
    This used fan shroud is back on Ebay again with no changes:
    https://www.ebay.com/itm/1636128556…em=163612855607
    Edited once, last by C6ZZKGT (April 14, 2019 at 5:29 AM).
  • This used fan shroud is back on Ebay again with no changes:
    This used fan shroud received no bids by March 30, 2019 and therefore did NOT sell.
  • This used fan shroud received no bids by March 30, 2019 and therefore did NOT sell.
    https://www.ebay.com/itm/1534347186…em=153434718654
    Edited once, last by C6ZZKGT (April 14, 2019 at 5:28 AM).
    This used fan shroud received no bids by April 6, 2019 and therefore did NOT sell.
    https://www.ebay.com/itm/163637591000?Vi...3637591000
    This used fan shroud received no bids by April 13, 2019 and therefore did NOT sell.
  • This used fan shroud received no bids by April 13, 2019 and therefore did NOT sell.
    https://www.ebay.com/itm/1636488398…em=163648839861
    This used fan shroud received no bids by April 20, 2019 and therefore did NOT sell.
    https://www.ebay.com/itm/1636587955…em=163658795520
    This used fan shroud received no bids by April 27, 2019 and therefore did NOT sell.
  • This used fan shroud received no bids by April 27, 2019 and therefore did NOT sell.
    This used fan shroud received no bids by May 4, 2019 and therefore did NOT sell.
    https://www.ebay.com/itm/1636770976…em=163677097616
  • Here is an Ebay auction for a used radiator fan shroud by Ebay member "mustangeer" with a starting bid of $75.00:
    Original service part C3DZ-8146-D, for 260 / 289 w/ air conditioning or 289 Special 4/B use. Has NOS tag and round shape in metal, factory dipped black paint drips are still there but with some chipping and surface rust in those areas. From a 1966 K-code. Keep you or that high revving High Performance engine a bit cooler with this part.
    https://www.ebay.com/itm/65-66-1965…DQAAOSwRrJdFDty
    Edited once, last by C6ZZKGT (July 1, 2019 at 3:36 AM).
  • Quote from C6ZZKGT
    [size=3][size=3][size=3][size=5][size=7]Original service part C3DZ-8146-D, for 260 / 289 w/ air conditioning or 289 Special 4/B use. Has NOS tag and round shape in metal, factory dipped black paint drips are still there but with some chipping and surface rust in those areas. From a 1966 K-code. Keep you or that high revving High Performance engine a bit cooler with this part.[/size][/size][/size][/size][/size]
    [size=7]https://www.ebay.com/itm/65-66-1965…DQAAOSwRrJdFDty[/size]
    This used radiator fan shroud sold July 6, 2019 on Ebay for $75.00.
    This used radiator fan shroud sold October 18, 2019 on Ebay for $199.00.
  • This used C3DZ 8146 D fan shroud sold March 3, 2020 on Ebay for $189.00.
