NOS C5ZZ 6038 A Motor Mount Insulator
  • Here is an Ebay auction for a pair of NOS C5ZZ 6038 A Hipo motor mount insulators by Ebay member "aboss429ataol" with a Buy-It-Now of $249.99:
    This auction is for a brand new NOS New Original Ford pair of motor mount insulators. These fit the 1965 Ford Mustang 289 Hipo Special High Performance V8. These are Ford part number C5ZZ-6038-A.
    https://www.ebay.com/itm/3517038889…e=STRK:MEWAX:IT
    Edited once, last by C6ZZKGT (March 23, 2019 at 4:30 AM).
  • Here is an Ebay auction for one NOS C5ZZ 6038 A Hipo motor mount insulator by Ebay member "magmustangs" with a Buy-It-Now of $199.00:
    1964.5-Early1966 Ford Mustang, Fastback, Coupe, Convertible, GT, Shelby GT350... NEW-OLD-STOCK 289 HIPO Motor Mount Insulator. Correct For LH or RH Side. This is an ORIGINAL FORD NOS PART. The rubber has molded C4ZA-6038-A (FoMoCo) and C5ZZ-6038-A numbers. This Insulator is Brand New-Original Ford. Ready To Install. Impossible to Find NOS for 289 Hipo.
    https://www.ebay.com/itm/1631379454…e=STRK:MEWAX:IT
    Edited once, last by C6ZZKGT (March 23, 2019 at 4:50 AM).
  • Here is an Ebay auction for a pair of NOS C5ZZ 6038 A Hipo motor mount insulators by Ebay member "orlandomustang1966" with a Buy-It-Now of $275.00:
    Fits Year (s): 1965-1966
    Description: Used set of Ford Mustang 289K Hi-Po or Shelby Motor Mounts or Rubber Insulators.
    Fits Model(s) & Type:
    Mustang / Fairlane
    Shelby
    289K Only
    Coupe
    Convertible
    Fastback
    Ford Part # C5ZZ-6038-A
    Eng # C4ZE-6038-A
    https://www.ebay.com/itm/2231428036…e=STRK:MEWAX:IT
  • Here is an Ebay auction for a pair of NOS C5ZZ 6038 A Hipo motor mount insulators by Ebay member "arizonavintageparts" with a Buy-It-Now of $199.00:
    NEW OLD STOCK ORIGINAL FORD [/size]FRONT MOTOR MOUNTS
    THIS LISTING IS FOR 2 MOUNTS
    (THE BUYER WILL RECEIVE 2 MOUNTS)
    THESE ARE NOT CHEAP OVERSEAS KNOCKOFFS-THESE ARE MADE IN THE USA BY FOMOCO
    IF YOU HAVE A POINTS CAR THESE ARE THE REAL THING-YOU CAN NOT GET ANY MORE ORIGINAL THAN THESE MOUNTS
    THESE MOUNTS ARE ORIGINAL FORD PRODUCTION (THEY STILL HAVE THE ORIGINAL FORD NUMBER MOLDED INTO THEM)
    MADE IN THE U.S.A.
    HAVE THE ORIGINAL BOXES-THEY DETERIORATED FROM BEING ON THE SHELF FOR SOME TIME
    THESE HAVE BEEN RE-BOXED AND VERIFIED BY US TO FIT THE BELOW LISTED APPLICATIONS
    THESE MOUNTS FITS EITHER LEFT OR RIGHT SIDE
    THESE MOUNTS ARE CLEAN AND SOFT+READY TO INSTALL
    FORD PART NUMBER:
    #C5ZZ-6038-A
    MANUFACTURERS CATALOG SAYS THIS FITS THE FOLLOWING:
    1965 TO 1966 FORD MUSTANG ALL WITH 260+289 C.I. V-8 ENGINE W/SPECIAL HI-PO 4BBL. CARB ENGINE
    (PRODUCTION DATE BEFORE 11-1-1965)
    1965 FORD FAIRLANE ALL WITH 289 C.I. V-8 ENGINE
    https://www.ebay.com/itm/1965-1966-…XQAAOSwWwtbOQ1o
  • The problem with these mounts is that they are actually reproduction pieces. The seller states that the original boxes had deteriorated from being on the shelf however Ford NEVER boxed these particular mounts. Yes, they have a Ford engineering number of C4ZA 6038 A but they are missing the Ford part number. Ford just used a tag, and sometimes rarely an ink stamped part number, on these over and above the C5ZZ 6038 A cast into the rubber below the engineering number. There are only two steps on the sides and ends of the Ford C5ZZ 6038 A mounts where these have three like the earlier ones for Fairlanes.
  • Here is an Ebay auction for a pair of NOS C5ZZ 6038 A Hipo motor mount insulators by Ebay member "welbury3028" with a Buy-It-Now of $185.00:
    289K Shelby Motor Mounts Engine 1965 Mustang Hi-Po Ford 65 NOS #1106.
    New never used!
    https://www.ebay.com/itm/289K-Shelb…m4383.l4275.c10
  • Here is an Ebay auction for a pair of NOS C5ZZ 6038 A Hipo motor mount insulators by Ebay member "bhwinc" with a Buy-It-Now of $189.99:
    No original boxes or packaging
    One pair of NOS
    Ford# C4ZA-6038-A/C5ZZ-6038-A Motor mount set
    1965-66 Mustang/ Shelby with 260/289 Hi-Po
    1965 Fairlane 289
    https://www.ebay.com/itm/1965-1966-…m4383.l4275.c10
  • Here is an Ebay auction for a pair of NOS C5ZZ 6038 A Hipo motor mount insulators by Ebay member "cobranda" with a Buy-It-Now of $188.00:
    1965 NOS MUSTANG
    (FITS ALL MODELS & ALL BODIES) K-CODE
    1965 NOS SHELBY GT350
    1966 NOS SHELBY GT350 CARRYOVER CARS ONLY
    289 K-CODE HIPO V8 ENGINE MOTOR MOUNT INSULATORS
    NOS FORD PART#'s: C5ZZ-6038-A
    2 BRAND NEW NOS FORD MOUNT INSULATORS: 65
    MUSTANG, 65 SHELBY GT350, & 66 SHELBY GT350
    CARRY-OVER CARS 289 K-CODE HIPO V8 ENGINE
    MOTOR MOUNT INSULATORS,
    BOTH MISSING the NOS WHITE STICKERS
    A 1-YEAR PRODUCTION INSULATOR: 1965
    NOTE: NOT for use on 1966 PRODUCTION MUSTANG or SHELBY MODELS
    https://www.ebay.com/itm/1965-NOS-M…~8AAOSwMJVdgMtp
  • This pair of NOS C5ZZ 6038 A Hipo motor mount insulators received no bids by November 5, 2019 and therefore did NOT sell.
  • Quote from C6ZZKGT
    This pair of NOS C5ZZ 6038 A Hipo motor mount insulators are back on Ebay again with no changes:
    https://www.ebay.com/itm/2333918306…em=233391830619
    This pair of NOS C5ZZ 6038 A Hipo motor mount insulators received no bids by November 12, 2019 and therefore did NOT sell.
  • This pair of NOS C5ZZ 6038 A Hipo motor mount insulators are back on Ebay again with no changes:
    https://www.ebay.com/itm/3333952651…em=333395265158
    This pair of NOS C5ZZ 6038 A Hipo motor mount insulators received no bids by November 19, 2019 and therefore did NOT sell.
    https://www.ebay.com/itm/3334041582…em=333404158245
    This pair of NOS C5ZZ 6038 A Hipo motor mount insulators received no bids by November 26, 2019 and therefore did NOT sell.
  • This pair of NOS C5ZZ 6038 A Hipo motor mount insulators are back on Ebay again with a new lower starting bid of $178.00:
    https://www.ebay.com/itm/3334135215…em=333413521556
    This pair of NOS C5ZZ 6038 A Hipo motor mount insulators received no bids by December 3, 2019 and therefore did NOT sell.
    https://www.ebay.com/itm/2334226145…em=233422614558
    This pair of NOS C5ZZ 6038 A Hipo motor mount insulators received no bids by December 10, 2019 and therefore did NOT sell.
    https://www.ebay.com/itm/3334330876…em=333433087647
