Jason, There is nothing different between the FoMoCo and the Autolite other than the names on the points and condenser. What matters is what is wrong with your FoMoCo one. Does it have bad bushings? Other than that, swapping parts will not change anything. I have encountered where the distributor cam is loose on the shaft, which is rare, and that made the Kar run poorly. If you had to, and the bushings are not loose, you can swap the two main shaft assemblies.
