C6ZF-C Autolite Carb
  • Sold for RESERVE NOT MET by seller darrylh99
    Bid to $860.69
    Quote
    This is an NOS Autolite carb for a 289 HiPo engine in a Mustang/Shelby with an manual transmission. This carb is NOS, and has literally been sitting on my shelf for 20+ years, and almost another 20 with a local engineering company before that. It is a part number C6ZF-C. It can be seen in the photos that the mounting flange and fuel line seat have never been used. It still retains all it's original ink markings. It has an 11-5-63 casting date, and is the 1.12" bore. It is missing it's aluminum tag that is under the left front screw, but the remnants of it are still under the screw. A reproduction can be made with any date code you wish. This is the last of the NOS HiPo carbs I have, and was the only manual tranmission one. Although it is brand new and mechanically moves freely, it's operation condition is unknown, so it is being sold as is.
    Ebay link
  • This used Autolite 4100 HiPo carburetor was SOLD for $578.00 by eBay seller "blueovalteam".
    SELLER'S DESCRIPTION:
    GOOD USED ORIGINAL HIPO CARBURETOR WITH ORIGINAL MATCHING TAG. UNFORTUNATELY, THE MANUAL CHOKE BRACKETS AND ROD ARE MISSING. THE PRIMARY VENTURI OPEN AND MOVE FREELY, BUT THE SECONDARIES ARE DIFFICULT TO OPEN. IT HAS BEEN SITTING MANY YEARS ON A MANIFOLD, AND HAS NOT SEEN GAS FOR A WHILE. I HAVE JUST REMOVED THE COVER, AND THE INSIDE IS CLEAN, BUT NEEDS TO BE CHECKED.
    TAG # C6ZF C / B 5JD
    CASTING # 6Z C
    APPLICATION: 66 289 K WITH MANUAL TRANSMISSION
    eBay LINK
