Bob Mannel's book chapter-2 2-22 shows two pictures top and bottom of a carburator spacer which included provisions for heating the fuel air mixture on all 1962- 221 and 260 engine's.Ford later went to a duct with a thermo heat flap on the air cleaner which worked off the pass side exhust manifold's on the 289's to achive appox. 100 degrees.On the Hi-po's with the open air, air cleaner's how is the mixture heated?
