• I have a K code with hipo engine in car with no flywheel. My problem is I want to put a lightweight wheel on for more performance.What weight balance do I need to buy to suit the Hipo engine.I know in reality I should have all parts balanced to be perfect and that will happen down the road but I just want to get it up and running first. can any one help
  • Quote from s2ms
    The HiPo flywheel is counter balanced to 30.4 oz.in.
    any suggestions of an aftermarket flywheel that willl do the trick?
    30.4ounce sounds hard to find
  • Get an aftermarket steel flywheel as most of those are 30lbs factory weight which is ideal for the Hipo and almost all of them are drilled for 10.5 clutch/pressure plate but always ask!
