FB Interior Rear Quarter Trim Panels
  • I have a question concerning FB interior quarter trim panels.
    The quarter trim panels that I received with my kar when I bought it are
    scratched, gouged, and have a number of holes in them. They need to be
    replaced.
    The additional sets that I have found are a little different from mine, in
    that they have a different part number.
    My set has an additional squared mounting tab at the center of the top edge of each qtr
    trim panel. It also has a larger forward-lower mounting tab with a key
    notch cut into the mounting tab.
    The part number on my trims are: Driver side C5ZB-C331071-EW
    Passenger side C5ZB-C331070-EW.
    The other sets I have seen recently have only two mounting tabs (differently
    shaped) on the top of the trim (without the middle tab) and also have a
    smaller forward-lower mounting tab that does not include a key notch.
    The part number on those trims are: Driver side C5ZB-C331071-KW
    Passenger side C5ZB-C331070-KW.
    What is a probable explanation for these differences? Is it that I have the 66 variety, because my kar was a Metuchen, June 1965 manufacture? The other sets are from earlier 65 cars.
    Thanks.
