Build your own using a windshield washer container off a late model car. Put a restictor in the end of the hose and make a fitting that sprays staight into the center of the carb.Wire the pump to a micro switch that you can hook to the throttle when wide open. Or you can just run a vaccum line from the bottle to the carb port with vaccum at wide open throttle. Ron
