Have read all the searches I can find and would appreciate some clarification.
The Ford small block is externaly balanced - yes.
The HiPo is balanced differently to other 289's. I gather early engines had a 28oz imbalance, later engines 50oz and HiPo 30.4oz.
Ok so how does this work ?
Is the crank is neutraly balanced ???
Does the damper have an imbalance of 24.5oz ?
Does the hatchet have an imbalance of 5.9oz ? making the two total 30.4oz.
How is the flywheel balanced does that have a 30.4 oz imbalance ?
If all of the above is correct does fitting the pistons and rods bring the whole lot back into balance ?
Or am I wrong ? If so could someone explain.
