Does anyone have a photo to share re where the Emergency Flasher in the glovebox is attached? Also was there a bezel for the switch in 1966?
1966 Emergency Flasher Location
It's attached to a 1966 only glove box. There's a hole for the cable/connector and two mounting holes in the box. The switch is mounted to a bracket retained to a backing plate on the top outside of the box by two pan head screws and two sems nuts. The NPD catalog has a picture (the cable hole is not punched out) that gives about a good as any idea of location.
Jim thanks for the input. My glove box does not have the holes shown in the NPD picture (nor does it have the clip). So it must have been replaced at some point with a 65 glove box.
