Disc Brake Master Cylinder Lines Routing
  • Hello,
    On the stock single cylinder masters for the 66 K codes, there are two ports. The top port,(which is located in the middle of the master) and the lower port. Can someone please look at their car and tell me if the top port plumbs into the proportioning valve, or does it go to the tee block that is mounted on the fender apron. I am trying to figure how to hook up these two lines coming off the master.
    Thanks in advance!
