10 x 2 1/2 rear brakes
  • i went junk-yarding the other day and picked up
    a ford airostar rear drumb 10 x 2 1/2. it fits.
    why do you need diferent backing plates. it looks like
    all i need to do is get the bigger shoes and the
    longer hold down pins. i dont see any diference
    between my stock backing plates and the airostar ones.
    thanks mark
  • I have 2-1/2 drums on my hipo.
    IIRC you will find that the 2-1/2 inch backing plates provide about 1/4 inch greater offset towards the center line of the axle housing. That combined with a similar 1/4 inch flatter drum face, provides the overall 1/2 inch of increased space required for the wider drum to index flush to the axle flange. Hope that makes sense.
  • but what im saying is.. that the 2 1/2 drum fits.
    it mounts flush with the axle flange (hub whatever)
    and does not interfere with the backing plate;
    it turns free. my old drum measured. 10x2.5 but
    would only accept 10x1.3/4 shoes (thats what started this whole idea)
  • OK now i understand, just because the drum fits
    doesnt mean that the shoes will fit. the correct
    backing plates actualy places the shoes 1/4" outboard.
    im done now.
