I'm in the process of replacing the 8" rear axle on my '66 fastback with a 9" and need location info of the Pinion Rebound Plate before installing the 9" Hipo rear end. I have the correct complete 9" axle and driveshaft.
I have a repro Pinion Rebound Plate and I've seen photos of an actual installed plate, but need to know the precise location for welding.
Is there a template(or can anyone provide the exact measurements from a couple reference points) to correctly position the Pinion Rebound Plate for welding to the floor pan above the 9" rear axle's nose?
The Rebound Plate gives the rubber "Snubber" bumper (mounted on the shield bolted to the axle assembly) something to bump against when hitting potholes, other than thin sheet metal.
Is there enough space to weld in the Rebound Plate after the 9" axle housing assembly is installed or must it be welded beforehand?
Any help will be appreciated.
