May 27, 2010 at 11:13 AM #1 I am trying to build up a 9" rear end. I found a pumpkin on EBay with the following parts in it:C6AW-4206C2AW-4210-BCan anyone tell if these parts belong in a hipo rear?
May 27, 2010 at 11:49 AM #2 There is no difference in 9 inch single rib cases other then date code.Find a case with about the same date code of your car and forget about the case being special to Hipo as they were not.The pinion support will be closely dated to case also.
